Mid volume bizhub heat rollers
  • JR2ALTA
    • Feb 2010
    • 2031
    [CQ] Mid volume bizhub heat rollers
    Is there a trick to reduce the center gouge that starts to appear after only a few dozen k prints?
    • 22999
    Re: Mid volume bizhub heat rollers
    If you think of one I'd like to hear it. I've got a bunch of bizhub 423's that the heat roller never makes more than 240K (on a 480K yield fuser).
    There is a Chinese supplier of heat rollers, but to make it worthwhile you've got to make a minimum order of 50. Care to split the order?
    • Hansoon
      • Sep 2007
      • 3374
      If this is the same issue as with the BH-350 B&W machines we cover the thermistors with thermistor tape. Before we push carefully the little thermistor "bulb", which protrudes out of the surrounding cushion, back with a wooden toothpick or match.
      Good results until now.
      Hans
      • Hansoon
        • Sep 2007
        • 3374
        BTW, be careful with some of those Chinese UFR's. I got one type which didn't last more than 10K. The Teflon surface was not black or dark grey as usual but a rather light grey color. From the same manufacturer we got also UFR's for the Di-450/550 with exactly the same problem.
        It seems as if the Teflon was not hard enough to withstand the friction of thermistor and separator fingers.
        Hate to admit but had to go back to Katun for the moment.........
        Hans
          • 22999
          Hans
          Thanks for the warning Hans. Katun offers them? With good results? 240K ++?
          • Hansoon
            • Sep 2007
            • 3374
            Yes Cat, We are using Katun fuser rollers for the DI-Series and also the BH B&W machines. They are not worse than the OEM but cheaper.
            I'm getting regularly parts from China from aftermarket suppliers/manufacturers but one has to be very careful. Quality is not constant even when the same item is coming from the same manufacturer another time. Also their way of handling and the communication with them is not easy. Recently I got a bunch of parts very different from what I ordered. I had the feeling that they just threw parts in the boxes to complete the total quantity regardless of type and use of those parts.
            Hans
              • 22999
              I've got six fusers sitting in the graveyard with 240K. I'd be delighted to see those fusers reach life. Thanks again for the good advice. =^..^=
              • JR2ALTA
                • Feb 2010
                • 2031
                After 200/250/350 I was shocked to STILL see this problem on the 223 series.
                Thanks all
                • Hansoon
                  • Sep 2007
                  • 3374
                  Give the Thermistor Tape Method a try. Its worth it.
                  Don't forget to push the thermistor bulb carefully inside as much as possible.
                  Hans
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Hans
                    Thanks Hansoon
                    • ni311
                      • May 2008
                      • 658
                      Do you have a code to order the thermistor tape from KM?
                      • Hansoon
                        • Sep 2007
                        • 3374
                        Its not from KM. My buddy from the USA got it for me from Precision Roller.
                        I had to do one today so I made some pictures of the procedure.
                        Hans
                        • Hansoon
                          • Sep 2007
                          • 3374
                          Here's an example. LFR for the Di-450 from China. Made 600 copies only then it disintegrated. The LFR bearings (OEM) where new ofcourse as well as the lower picker fingers so that could not be the cause of this damage. It seems that the silicone didn't bond to the metal core and became loose causing bubbles in the rubber which than tore because of the friction.
                          Hans
                          • Darren King
                            copiertech
                            • 652
                            A lot of the time trying to save ten bucks costs you 100 bucks in callbacks.
                            • Hansoon
                              • Sep 2007
                              • 3374
                              "Ten Bucks"????
                              LFR for the Di-450 from Katun costs USD 110.00 (OEM would be even more, you must know) The same roller from Chinaman USD 15.00
                              So if I need ten pieces I save USD 950.00.........
                              Darren, for a small company like ours this makes a very big difference. Usually most of the aftermarket parts work well but you have to know your partners overthere.
                              Hans
