bizhub 423 drum replacement question
  • brent
    • Nov 2008
    • 1214
    actually a dumb question. but once the change pc drum message comes on. how many copies can be made? I know the bizhub 350 will say replace drum. but it will not stop the machine. from what I seen. a couple at like 170 percent.. but I am working on the bizhub 423. any thoughts?
    I do have the book. just not with me at present time. thanks
    brent
    • 23010
    Re: bizhub 423 drum replacement question
    980 minutes running time. Depending on how your machine is used that translates to anywhere from 5K to 30K prints
    Print off the Consumable List. The message comes on at 3921 minutes, then cuts you off at 4901 minutes. =^..^=
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      With special firmware it will run till failure.
      • brent
        • Nov 2008
        • 1214
        I just need it to go a few days. Thanks
        • JustManuals
          • Jan 2006
          • 9838
          brent
          That's why a soft copy in a .pdf file is better, you can put it on a flash drive and even if you don't have your laptop with you, you can use the customer's PC to access it.
          Paul@justmanuals.com
          • brent
            • Nov 2008
            • 1214
            thanks paul. I have full access to the kmbs website. I have all the manuals. it was loaded on my computer. but I didn't have it either.. lol thanks
            brent
            • Mr Spock
              • Aug 2006
              • 2064
              Once the replacement message comes up you have to replace it. If you can get it before hand then the firmware will allow it to go to failure.
              • CraigW
                • Dec 2010
                • 417
                Those models require "drum dry"procedure, that was a new one for me.
                And, you have to look close at the parts life counters to make sure you clear the correct one.
                  • 23010
                  If your near the end of life on the developer you'll get a C2557 during the drum dry procedure. Don't panic. It happens all the time. Do your PM including developer change. Clear the error with Trouble Reset. Then do the TCR sensor adjust and Gradation. =^..^=
                  • kingarthur
                    • 1383
                    I have successfully set the softswitches when the warning has appeared, so the message has disappeared, without fitting any parts
                    • CraigW
                      • Dec 2010
                      • 417
                      Thanks for the heads up.
                      Drum dry is done 1st before removing the items from best I could tell using adjustment list.
                      Correct ?
                        • 23010
                        Correct ?
                        Reset the appropriate counts > perform drum dry > power Off > do PM > power On > perform TCR sensor adjust > perform Gradation.
                        Correct. =^..^=
                        • CraigW
                          • Dec 2010
                          • 417
                          I reset counts after drum dry as per the adj list order.
                          Really do like the 200-423 series. Great machines.
                            • 23010
                            Me too. I've got a couple with 750K and plenty of life left. =^..^=
