C250 print scan dead
  • mrfuser
    • 1617
    Ok, replaced hdd and print sca. Works for a bit but as soon as we try to print a config report it locks up again.
    any ideas?
    kelly
  • kon
    • 55
    Re: C250 print scan dead
    any ideas?
    kelly
    The controller is set to OTHER.
    To change:
    1. In the TECH REP mode select System 2 and Image Controller Settings.
    2. For an external Fiery IC-402 or IC-405 controller, set the controller number to 1.
    3. For the STANDARD built-in controller the Peripheral setting would be controller 0.
    • mrfuser
      • 1617
      No it is set correctly. We can scan and fax but as soon as they try to print test page or from Pc it won't print.
