C35 lines copy only.jpgI have a c35 problem. Whenever a colour copy is done (from df or glass), it prints evenly spaced vertical lines on the output. A mono copy prints normally. Prints from the PC or internally generated prints come out fine. The mfp and prcb have been changed for an unrelated fault and were replaced following the procedures in the manual. Unfortunately I dont know if this particular problem was evident before the boards were replaced (I inherited the call). The firmware is all up to date. anyone have any ideas?
C35 lines
Re: C35 lines
[ATTACH=CONFIG]18702[/ATTACH]I have a c35 problem. Whenever a colour copy is done (from df or glass), it prints evenly spaced vertical lines on the output. A mono copy prints normally. Prints from the PC or internally generated prints come out fine. The mfp and prcb have been changed for an unrelated fault and were replaced following the procedures in the manual. Unfortunately I dont know if this particular problem was evident before the boards were replaced (I inherited the call). The firmware is all up to date. anyone have any ideas?
good luck.The gene pool could use a little chlorine. -
Re: C35 lines
Thinking about it. Try setting the machine up as though it is a new machine agiain, I'm sure you get these lines on a C35 if its not set up as per the instructions........The gene pool could use a little chlorine.Comment
Re: C35 lines
[ATTACH=CONFIG]18702[/ATTACH]I have a c35 problem. Whenever a colour copy is done (from df or glass), it prints evenly spaced vertical lines on the output. A mono copy prints normally. Prints from the PC or internally generated prints come out fine. The mfp and prcb have been changed for an unrelated fault and were replaced following the procedures in the manual. Unfortunately I dont know if this particular problem was evident before the boards were replaced (I inherited the call). The firmware is all up to date. anyone have any ideas?Comment
Re: C35 lines
Are these the "Lines Of Shame"?
If yes, try running through your setup procedure one more time. I've seen them in cyan, magenta, and yellow, but never black. The spacing is about right. I've seen them on C360, C452 and C652. I think it's worth a try. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: C35 lines
C35s don't get lines of shame, since there is no setup, we have had several with main pwb issues and hv unit, I would tend to think it is with hv unit especially if someone previously removed it, also if it wasn't plugged into surge protectorComment
