Konica c652 installed PI-505 Post Inserter
  • Oscar57
    • 79
    Hi,
    Just installed a PI-505 Post Inserter on a Konica C652. It works fine printing through the Fiery. But when I try to use it offline for some folding the on/off button is lit amber instead of green. Is there a setting in service mode or a software switch setting that must be changed. I'm stuck so any input would be much appreciated.
  • Flash
    • 378
    Re: Konica c652 installed PI-505 Post Inserter
    Try doing the paper size adjustment and make sure the paper is in the same orientation as the main body paper supply.
    • Oscar57
      • 79
      Yes, I tryed that already. It seems almost like it should be in a different mode for offline operation. I'm hoping its a software setting?
      • Itsthepaper
        Supervisor
        • Dec 2007
        • 91
        Considering you followed the paper size detection adjustment after install properly then check out bulletin TAUS0902717EN00. Firmware updates to improve the capabilites of the PI-505.
        Love the Job Love the Work.
          • 23010
          Yes, I screwed up the size adjustment the first time around. Be sure to read the procedure all the way through. It won't function at all until the size is adjusted correctly. =^..^=
