P21 on bhC252 AFTER REPLACING TRANSFER UNIT
  • juve
    • Dec 2012
    • 86
    Hello
    today i replaced a transfer unit because it was indicating for replacement(on a bizhub c252).after replacing the unit,and after stabilization,the copier marks the oil can p21.manual tells me either to clean surface of the transfer unit or to replace!and it's new,no damages at all.can somebody give me a clue?
  • avecosat
    • Jun 2012
    • 305
    Re: P21 on bhC252 AFTER REPLACING TRANSFER UNIT
    Clean the AIDC sensors down the transfer belt .
      • 23003
      Ditto that. =^..^=
      • juve
        • Dec 2012
        • 86
        ok, I cleaned idc sensors and inlet of belt and p21 solved.thanks
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          you should do this, among other things, every time a transfer belt is changed or removed for any reason, to just put a new belt in and walk away is sloppy workmanship.
          • juve
            • Dec 2012
            • 86
            ok mate,thanks for the advise,I just started working full stream on the color copiers only this month,and many things i will have to learn them on the field.in the manual there is also indication that gradiation adjustment have to be done when replacing the belt.i knew that I had to do this on installation but not also when replacing belt,infact i cleaned well and p21 vanished without the need of grad adjustment
              • 23003
              Maybe you didn't have to, but image quality will be much much better. This isn't like Sharp, you can complete a gradation in 10 minutes. You should do a gradation when replacing any image quality component. =^..^=
              • MAD0RAM
                • Oct 2012
                • 81
                X2
                • juve
                  • Dec 2012
                  • 86
                  for next time then.
