Bizhub 250 second side poor quality
  • mrfuser
    • 1613
    Simplex is perfect. Replaced drum unit with new and same result. Is this a bad dv unit?
    kelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 250 second side poor quality
    Paul@justmanuals.com
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      did you replace the developer at the same time as the drum as your supposed to ?
      i would change the developing unit anyway, and make sure the transfer roller hasnt done more than 150k. if it has it should be changed.
      • mrfuser
        • 1613
        I know you are in the business of selling manuals but please do not post in my threads anymore. It is unprofessional and annoying. At times I drive 20 minutes one way just to find out it was your spam!
        please stop!
        Kelly
        • JR2ALTA
          • Feb 2010
          • 2030
          kelly
          wtf do you mean by poor quality? smudgy, light, streaks, blurry?
          for perfect quality drum, dev, dev unit, t-roller, fuser
          also, you must clean registration bushings! two on front two on back. time and developer sneaks in and causes bushings to deform and hollow out. this can cause image problems.
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1250
            kelly
            I have had some bad results in the past replacing only the drum unit in BH 200 and 250's and now religiously replace the dv unit and drum unit as a set. Copy quality issues are commen if you don't...and also the dv spacers wear down and the new drum unit surface can be scored down to the aluminum base because the distance is too close. DV units and drum units are fairly inexpensive for these units. Replace both .... add starter and run F8 and you should be done.
            • juve
              • Dec 2012
              • 86
              kelly
              usually,when replace drum I replace also developer,and even dev unit due to the defective meg.roller bushings,but you say duplex,so i will clean well the duplex rollers,t.s roller ,registration roller and even feed rollers(rubbers).
              • Gian Carlo
                • Feb 2013
                • 5
                poor contacts of bias in the transfer roller section.
