Bizhub C35 / NEC My Office C350
  • Ben Around
    • Apr 2012
    • 151
    Is anybody having problems with these machines misfeeding from tray 2 or tray 3? We have a handfull of them in the field and every one of them have the same problem. We've played with the mylar, replaced the one-way bearings, swapped paper trays but nothing seems to make them feed reliably.
    The paper never leaves the tray when the misfeed occurs.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub C35 / NEC My Office C350
    Paul@justmanuals.com
    • Ben Around
      • Apr 2012
      • 151
      Is that all you have to offer on every post?
      • mmru4real
        • Aug 2008
        • 67
        Put a shim between the 2 trays we have done this to everyone of our machines for the same issue and it resolved the problem on 12 machines.
        • mmru4real
          • Aug 2008
          • 67
          The shim should be on the left side near the front corner between tray 2 and 3. I can post pictures next week, it has fixed every machine we have that has the additional tray
          • Ben Around
            • Apr 2012
            • 151
            Thank you for your response mmru4real. I must admit that I'm somewhat skeptical about your approach, but results are results. Please post the pictures, that would be great. And they are worth a thousand words.
            • scottybbb
              • Dec 2010
              • 126
              I would like to see a picture of the shim also.Thanks.
                • 22999
                Now I'm curious. Any theory what the shim does specifically? =^..^=
                • JR2ALTA
                  • Feb 2010
                  • 2031
                  My thoughts.
                  Tray 3 (optional tray) has three mylars between the primary and sep rollers. That's ridiculous, of course paper will bind and not feed. I remove one with an exacto.
                  Also, I tell customers to clean up the big roller and fan the paper frequently.
                  We have sent 3 C35s back to Konica
                  They jam, they skew. Tell your sales to keep expectations reasonable. people want production print with these, aint gunna happen.
                  but yea, i want to see pic too
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Utilise the forums ignore list if there are people you don't wish to see posts from - that's what its there for.
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      the other thing that's shitty about the option trays on the c35 is the right side door catches being spot welded to the frame and breaking off - in order to fix it you have to drill a suitable sized hole and use one of the standard km machine screws.
                      • krm
                        • Aug 2009
                        • 233
                        These color machines? I worked at a dealership with many color biz hubs and we were busy with firmware, mods., bad IU's and loads of machine issues. ( Not generally $ making.) Not by design, my current company has mostly black n white. We are not nearly as busy with abnormal -premature issues, like these color machines generate. Am I the only one who feels this way? I know color is the future, present, etc., but I don't miss trying to explain all the new machine failures to customers'.
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          The machines are built in china by 16 - 17 year old's who are employer housed on camp and paid $2 a day. Smiles are not something you will see in this work place.
                          If you think any of the other mass produced brands of anything made there are any different, you are sadly mistaken.
                          When all people care about is getting things as cheaply as possible, THIS is the future.
                          • RRodgers
                            • Jun 2009
                            • 1947
                            I guess he hasn't "Been Around" long enough to realize that. LOL
                            • Ben Around
                              • Apr 2012
                              • 151
                              Ha Ha ha, that was so funny, like when a customer tells a tech they should put him on the payroll.
