orientation scan problem
  • zuper
    • Apr 2012
    • 25
  • Synaux
    • Mar 2012
    • 1224
    Re: orientation scan problem
    Not sure I can help you without a model number...
    But I can't think of a setting that will mess with page orientation only on specific pages--in my experience.
    • zuper
      • Apr 2012
      • 25
      sorry, the model is bizhub 420
      • kingarthur
        • 1356
        are you scanning landscape or portrait, have you got samples
        • zuper
          • Apr 2012
          • 25
          Hi! I have more information
          the problem is when i scanning from document 2 side and the paper size is 8.5*13in. if is 8.5*11 scan normaly
          i attach an example
          what I can tray?
          thanks
          • kronical
            Kronic Copier Ninja
            • Nov 2009
            • 230
            i attach an example
            what I can tray?
            thanks
            8.5x11 feeds long edge first, and comes out fine... 8.5x13 can only be fed short edge. Make sure you specify under Original Settings the correct orientation and binding direction of the original.
            • zuper
              • Apr 2012
              • 25
              Hi, I am sure i specify the god orientation and direction, but scan wrong
              feed the short edge (is only way) and i chose the original setting horizontal
              • zuper
                • Apr 2012
                • 25
                You are right! The binding, was The binding!
                Thank you very much!
