Bizhub C452 - background in one corner [scanning from flatbed]
  • -ph-
    • Jun 2009
    • 30
    Hi,
    This afternoon I ran into this problem, when making an A3 scan from flatbed there's one corner with background [the corner nearest to the operating panel] if I make the same scan from the feeder I have no background. The feeder closes correctly, I checked and cleaned the optics and ran through stabilisation and grad. adjust, but no result.
    check image below:
    any ideas?
  • mrwho
    Major Asshole!
    • 4299
    Re: Bizhub C452 - background in one corner [scanning from flatbed]
    Bent scanner. Someone's been leaning over it while taking copies.
    Mascan42
    Ibid
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      yep, seen this before. I agree with mrwho.
      Or if its a new machine, its been damaged in transit and I'd write it off or reject it.
      • -ph-
        • Jun 2009
        • 30
        Thanks for the response, i'll try to bend, hope it will work out.
          • 23009
          Ditto that. Until you get it focussed properly it won't complete gradation. =^..^=
          • BennyAU
            • Dec 2012
            • 25
            had one of these machines do the same thing at run-up
            tried replacing ccd unit, all associated cabling, none of it worked
            didnt check the framework, but we just sent the machine back and got a replacement.
            for your sake, i hope its not a field machine, because i wouldn't want to have to replace the framework
            • -ph-
              • Jun 2009
              • 30
              problem solved, it was just a matter of bending the scanner back in its correct position, trail and error, luyckily it was pretty easy.
              • mrwho
                Major Asshole!
                • 4299
                Thanks for the input! Reps to you!
                Mascan42
                Ibid
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  We've had a nutter sit down and graft the top end of one scrap machine onto a field machine, it wasn't actually that hard but just quite a bit of time required.
