BH 223/283/363/423 Fuser rebuilds
  • maccopy
    • Oct 2012
    • 5
    Anyone rebuilding these units?
    A new fuser is over $300. Konica Minolta does not list individual parts. Many of the parts are the same as BH350 but the thermistors are different, looking for a part# or source for thermistor.
    • 23009
    Re: BH 223/283/363/423 Fuser rebuilds
    I've found heat rollers at Katun, but have not found heat roller claws yet. These fusers typically last 240K before the heat roller peels at the claws. I believe that the pressure roller and bearings will last the full 480K.
    Does anybody know a part number for a compatible hr claw, and/or a source? =^..^=
    • CraigW
      • Dec 2010
      • 417
      We have quite a few of these showing problems very early on, 36 & 42s as well.
      The 200 series fusers would last forever.
      These are failing very quick for what they cost.
      • emujo
        • Jun 2009
        • 3009
        You can get the specified life out of most of them if you take a moment and clean the thermistor at each service call. I'm not saying they don't fail early though, even the new 4 series fusers are crapping out around 100K. Emujo
        • CraigW
          • Dec 2010
          • 417
          It does mark at the safety stat but we also get wear at the claws.
          Like at the rear, and the line is a short way from the top.
          • PeterG
            • Jul 2008
            • 177
            I seem to recall reading something on CSES about upping the fuser temp by 5 Degs to help reduce the wear.
            I will see if I can find it.
            • krm
              • Aug 2009
              • 233
              I rebuild the Bh200/2510 fuser with a $100.00 kit. VS. $300 fuser at Minolta, but it takes a couple hours to do all the parts/orange rollers, etc. and clean + lube. I did one on site at busy law firm and it was stressful with everyone holding reams of paper looking at me. I'm wondering if it's worth the time vs. just buying it?
              • copierguru
                • Jul 2011
                • 27
                I re-build these all the time 423/250. I've found the oem fusers are all over the place in yields. I've got some that last usually 100 - 150K and I've had some go almost 300K. I just replace the ufr (muratec branded) p/n DA14705060. I can replace these in under 30mins. I also get rid of the the grounding clip that's rides under the ufr on the right side so theres no squeaking. Been doing it for years and no problems
                • Hansoon
                  • Sep 2007
                  • 3390
                  Same to me for the BH-350 series. I need about 40 minutes however but I reinstall the grounding clip, perhaps that's why?
                  Hans
                  • Accentcp
                    Old Tech
                    • May 2008
                    • 14
                    Hans
                    Are you sure the BH3510/350 upper fusing roller will work in the BH363/423 series fuser units?
                    • Toxic
                      • 698
                      Hi,if i understand good,fusing roller from bizhub 250/350 fits for Bizhub 223/283/423?
                      I have one Bizhub 223 with error code C-3723, but machine have near 500k and fusing roller look like horor and finaly stop working
                      Is this highest fusing life here in this topic?
                      • CraigW
                        • Dec 2010
                        • 417
                        450K Is the rated life on these.... many will have marks on prints very early on (less then 100k)
                        • gitana1983
                          • Mar 2009
                          • 141
                          Question,
                          Any idea where to get the thermistors for the MInolta Bizhub 423? I already have a kit with both rollers but need urgently the thermistors, any help will be appreciated.
                          • allan
                            RTFM!!
                            • 5462
                            There is 3de party thermistors available for BH224 that works fine. Bad toner is a killer on the upper roller.
                            Whatever
                            • gitana1983
                              • Mar 2009
                              • 141
                              I know is a little too late, Copylite has a kit that comes with both rollers and fuser claws, but is missing thermistors, if by any chance you were able to find them somewhere else, please point me in that direction!
