White spots.
  • Imsdal
    • Aug 2009
    • 111
    White spots.
    I Went to see a customer with a KMBH C353 and the result is very strange. When I choose the type of paper thick 3 or 4 the result come with white spots and when I choose thick 2 or plain paper the result be okey. Does anybody seen this problem before. Cheers David
  • SmellsHot
    Head Tech
    • 512
    Re: White spots.
    Then don't use thick 3 or 4 if it works fine on 2 and 1........Different speed/temp/voltages when changing paper type.....also depends on type of paper your using too.....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • SmellsHot
      Head Tech
      • 512
      Re: White spots.
      In my experiences sometimes the thickness setting is a guessing game......
        • 23009
        Re: White spots.
        From what I can see from your images, the thick3/4 image is either arcing or pulling developer. You may be able to put off for a little while longer replacing imaging unit(s), but I'm thinking it will be soon. What's the count/minutes on these imaging units? If you print this original, which colors are affected?: See attached:
        • marlon29
          • May 2011
          • 51
          Re: White spots.
          hi,
          try changing the second transfer values for thick 3/4 into -20 and the fusing transport speed to -20 also
          hope this will help
          marlon
          • anothertech
            • 1771
            Re: White spots.
            Yeah, I think marlon29 has it, turn down the second transfer and you'll be good to go.
            • Flash
              • 378
              Re: White spots.
              If you have been resetting the transfer belt counter instead of replacing it you might need a new transfer belt unit.
              • Michko
                • Sep 2010
                • 32
                Re: White spots.
                I got this on a C280. SAME issue with white dots on thick3/4 in Cyan.
                • JustManuals
                  • Jan 2006
                  • 9838
                  Re: White spots.
                  Paul@justmanuals.com
                  • davidj7
                    • 1107
                    Re: White spots.
                    Hi
                    Not to hijack this thread but i am having similar problem in BizhubC220 i am betting on developer unit.Replaced drum units,IBT is new less than 10K, replaced developer material problem reappears after 500 prints. I will get a new one by Wednesday ,will update here once i replace.
                    a machine is only as good as your tech : source:screwtape ; the scary one
