C654 ERROR CODE 7219
  • Kenny
    • Jun 2009
    • 541
    Morning chaps have a Konica Minolta c654 bringing jam code 7219 ? anyone seen this before ?
    thanks
    Kenny
  • Avskrap
    Partner in crime
    • Jul 2011
    • 160
    Re: C654 ERROR CODE 7219
    Jam codes beginning with 72xx is a FS jam code. What FS is mounted on the machine? What are the symptoms? Paperweight? Folding?
    • blaze2000
      • Sep 2010
      • 232
      Check the bypass switching gate solenoid in the finisher it might be dead or have a broken spring. We also had one have a board failure causing intermittent jamming but I don't recall if it was a 72-19, good luck
      Replace SD2 (p/n A11PR70211).
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        presuming its FS-535, if yes, it is the bypass gate solenoid spring broken. VERY common on this and FS-526.
        Done it MANY times now.
        • JustManuals
          • Jan 2006
          • 9819
          Paul@justmanuals.com
          • Albertoner
            • Jun 2016
            • 6
            Thanks man, i try it tomorrow.
            See you
              • 22995
              Is it a FS-534? Maybe this will help:
              http://www.copytechnet.com/forums/ko...e-wearing.html
