Bizhub colour C280 jams code 32-05
  • tekkie
    • Mar 2011
    • 114
    [Jamming] Bizhub colour C280 jams code 32-05
    Machine jams intermittently more on A3 than A4 and it doesnt matter which cassette A3 is fed from, it jams from both cassettes.When it jams the paper is concertinered it has fed a few inch through the fuser rollers then stops and crunches up.Its not fouling or catching anything the lead edge is perfect and has fed through rollers and then it seems to stop and the paper crunches up behind it.It has done 150k in total has had a new fuser unit about 80k ago due to damaged rollers and it has latest firmware.Any ideas anyone.Ive changed the fuser exit sensor and checked its operation in service mode and its ok.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub colour C280 jams code 32-05
    Paul@justmanuals.com
    • blaze2000
      • Sep 2010
      • 232
      Do you have a finisher installed?
      • blaze2000
        • Sep 2010
        • 232
        Bulletin
        check out bulletin 7587 ...
        7587.pdf Download
        Guide_Replacement_Procedure.pdf Download
        Parts_Mod_Notice-Fuser.pdf
        • tekkie
          • Mar 2011
          • 114
          no finisher installed
          the model i have is an olivetti dont have access to konica bulletins can you supply info pls
          • blaze2000
            • Sep 2010
            • 232
            ok here's the info....
              • 23010
              Jam code?
