bizhub c25 constantly jamming onduplex
  • malthus
    • 29
    [Jamming] bizhub c25 constantly jamming onduplex
    I have bizhub c25 constantly jams indouble sided mode have tried changing boards main motors sensors but the paper is not fed back in for second side and registers an output jam both clutches have also been changed
    any one have any ideas
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub c25 constantly jamming onduplex
    Paul@justmanuals.com
    • malthus
      • 29
      [QUOTE=JustManuals.com;368590]This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from:
      [malthus/QUOTE] dont need any manuals have full access to infohub
      • Kevin12
        • Nov 2011
        • 8
        Hi
        Did you manage to sort this problem out?
        • copier tech
          • 8133
          I expect so as it was nearly 3 years ago!
          • guycampo
            • Aug 2015
            • 6
            What did you do to fix it? I have the same problem and I went thru the same exact replacement of components.
            Thank you
            GC
            • JR2ALTA
              • Feb 2010
              • 2031
              Thank you
              GC
              You might have a gap between the idle and drive rollers. Had this problem, brought into shop and found that plastic door wasn't snapped in probably to duplex section. It was a long time ago, i think it was a c25 or comparable
