Bizhub C451 Aging
Re: Bizhub C451 Aging
WTF? One can still see the wipes.........
A Redneck Solution if you allow me to say so...... Wondering how much seeped into the cleaning system gooying up everything.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
I remember on the C350's the auger in the t-belt would usually break. This was due to people not putting the waste toner box in properly. The waste toner would back up and start pouring out of the cleaning blade. Vac out your cleaning station on the t belt. If it starts making good copies again then that is your problem.
**EDIT**
WOW, not sure why I was thinking C350.Last edited by RRodgers; 07-25-2013, 07:30 PM.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
You were only supposed to clean the blade of the transfer belt, not the entire belt! Wow... Aftershave... that's just... Wow.Comment
Does it smell better? That's all that counts. =^..^=If you'd like a serious answer to your request:
Ohh Aftershave, does sound like a bad joke.
Not a pure enough source of alcohol. Obviously. If it got into any electronics it would be a problem as well as it could leave a slightly conductive residue, where pure alcohol wouldn't.
alcohol would also basically eat any bio based coatings, Given the rainbow effect you got going on I would wager you used it on the drums too didn't you. :-)Comment
as per usual, trying to save a few dollars has caused more damage than if you just followed the advice given in the first place.
never argue with a person that only accepts responses that don't cost money, just walk away and let them figure out the hard way.
my avatar sums up the efforts without using any words at all.Comment
All right you all had your part of funnow leme update ya all
After a good shave the machine is working back to normal printing, i guess all the after shave has dried up now
there are no smudge marks any more on the paper, and the prints are darker then the one i posted above
how every the lines on the transfer belt are more visible now on the color prints/copies
and over all prints/copies are still just a light lighter, could it be drums or is it still the belt?
Off course the belt needed to be changed, i am waiting for a used one to arrive soon.
* a lil bit of cleaning might extend the life a bit moreit would have worked well if i had pure alcohol i guess
well lifes like that, you gota do what ya gota do :PComment
I think you're kicking a dead horse here, some stretching of the consumable life is easily possible however when you start down the road you're on there is not much else to do but actually spend a couple bucks on a proper maintenance. Seriously stuffing in used parts and such, you seem to approach maintenance in a very, well let's be polite, a Frugal manner. This is not always conducive with maintaining the highest standards of image quality or device performance. Just pony up a few bucks and you'll notice a marked improvement in quality and performance.Comment
So, what else can we use from the bathroom? Toilet paper for filtres? Shaving creme for a cleaner. What could we use the plunger for? hmmmm
And why stop in the bathromm? I'm sure there are a lot of things around the house to use for copier repair.Last edited by Copier Addict; 07-30-2013, 09:25 PM.Comment
And why stop in the bathromm? I'm sure there are a lot of things aroung the house to use for copier repair.
Sorry, I was carried away....
daniel.vasiliev
