Bizhub C451 Aging
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C451 Aging
    Originally posted by konica7022
    well it contains "alcohol", water, perfume!
    Then maybe on the next machine you may want to bring some tequila, go ahead and stick with the aftershave, give the customer the tequila so they are drunk enough to not notice the copy quality. Emujo
    • Hansoon
      • Sep 2007
      • 3391
      WTF? One can still see the wipes.........
      A Redneck Solution if you allow me to say so...... Wondering how much seeped into the cleaning system gooying up everything.
      Hans
      • RRodgers
        • Jun 2009
        • 1947
        I remember on the C350's the auger in the t-belt would usually break. This was due to people not putting the waste toner box in properly. The waste toner would back up and start pouring out of the cleaning blade. Vac out your cleaning station on the t belt. If it starts making good copies again then that is your problem.
        **EDIT**
        WOW, not sure why I was thinking C350.
        • BDT Tech
          • 12
          #19
          It's not very often that I am speechless. Aftershave? Wow, who would of thunked it?
          • PrintMasterBuc
            • Jan 2013
            • 13
            #20
            You were only supposed to clean the blade of the transfer belt, not the entire belt! Wow... Aftershave... that's just... Wow.
              • 23010
              #21
              Does it smell better? That's all that counts. =^..^=
              • gl0ryh0und
                • 15
                #22
                Ohh Aftershave, does sound like a bad joke.
                Not a pure enough source of alcohol. Obviously. If it got into any electronics it would be a problem as well as it could leave a slightly conductive residue, where pure alcohol wouldn't.
                alcohol would also basically eat any bio based coatings, Given the rainbow effect you got going on I would wager you used it on the drums too didn't you. :-)
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  #23
                  as per usual, trying to save a few dollars has caused more damage than if you just followed the advice given in the first place.
                  never argue with a person that only accepts responses that don't cost money, just walk away and let them figure out the hard way.
                  my avatar sums up the efforts without using any words at all.
                  • konica7022
                    • Nov 2008
                    • 132
                    #24
                    All right you all had your part of fun now leme update ya all
                    After a good shave the machine is working back to normal printing, i guess all the after shave has dried up now
                    there are no smudge marks any more on the paper, and the prints are darker then the one i posted above
                    how every the lines on the transfer belt are more visible now on the color prints/copies
                    and over all prints/copies are still just a light lighter, could it be drums or is it still the belt?
                    Off course the belt needed to be changed, i am waiting for a used one to arrive soon.
                    * a lil bit of cleaning might extend the life a bit more it would have worked well if i had pure alcohol i guess
                    well lifes like that, you gota do what ya gota do :P
                    • gl0ryh0und
                      • 15
                      #25
                      I think you're kicking a dead horse here, some stretching of the consumable life is easily possible however when you start down the road you're on there is not much else to do but actually spend a couple bucks on a proper maintenance. Seriously stuffing in used parts and such, you seem to approach maintenance in a very, well let's be polite, a Frugal manner. This is not always conducive with maintaining the highest standards of image quality or device performance. Just pony up a few bucks and you'll notice a marked improvement in quality and performance.
                        • 14977
                        #26
                        So, what else can we use from the bathroom? Toilet paper for filtres? Shaving creme for a cleaner. What could we use the plunger for? hmmmm
                        And why stop in the bathromm? I'm sure there are a lot of things around the house to use for copier repair.
                        • Hansoon
                          • Sep 2007
                          • 3391
                          #27
                          And why stop in the bathromm? I'm sure there are a lot of things aroung the house to use for copier repair.
                          Scratching the Teflon out of a frying pan and............
                          Sorry, I was carried away....
                          Hans
                          • daniel.vasiliev
                            #28
                            I had the same problem, changing the K image unit solved the problem.
