BizHub 601 toner in fuser?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    Machine is getting toner build up in fuser. Toner baked on entrance plate, plate where pick off fingers are, white rollers, etc. I rebuilt fuser and cleaned all toner off plates, rollers,etc a few weeks ago and it is already dirty again.
    Toner is not piled up on transport bed. I'm aware of that problem.
    Using TN-710 OEM toner and customer is not leaving lid open when copying.
    I have turned turned down toner density with soft switches. Also have cleaning-recycling unit to stay on all the time
    Can't think of anything else. Didn't see anything on K/M knowledge base.
    Any help appreciated.
    • 14725
    Re: BizHub 601 toner in fuser?
    It could be developer dumping. These pigs are bad for that. Try cleaning the charge grid, if that doesn't solve the problem replace the grid.
    Hope this helps
    • aazim
      • Dec 2012
      • 14
      Hope this helps...
      Best Regards : Anton
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        These run dirty and require meticulous maint , parts replacement ,and PM's. Very similar to the 7255's which were pigs also. That being said, other than running dirty, they are good boxes if you replace the parts they need at regular intervals, especially the charge grid and developer. That toner on the fuser inlet guide doesn't surprise me as it is common for web residue to make that plate sticky and then it gets and stays dirty until we clean it. What's the meter on that box? Did you check the parts counters to see parts life?
        • copyman
          Owner / Technician
          • Sep 2005
          • 4701
          Thanks For the replies. 350k clicks on meter. I will try some of the suggestions. Getting some build up on the entrance plate which I have seen with Konica Minoltas going back to the EP4000.
          The real problem is the toner build up on the plate where the pick-off's are and the 2 white plastic rollers on that plate.
          I was back there today and installed 250k PM kit. Also checked that LFR lamp was lighting. I was thinking maybe the temp was to low but lamp is lighting. The fuser seems extremly hot so I will try turning temp down.
          Thanks again
          • aazim
            • Dec 2012
            • 14
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Did you reset the web cleaning unit counter? If you do not reset this the you can get toner build up real bad at the roller.
              Solution ID TAUS0701149EN* Solution Usage 2
              Description
              Dirty copies. The fixing cleaning web is not advancing.
              Solution
              CAUSE:The fixing unit web solenoid is not activating even though the solenoid operates in diagnostics. The fixing unit cleaning web counter was not reset
              after replacement.
              SOLUTION: To reset the cleaning web counter, perform the following:
              1. Enter the Tech Rep mode.
              2. Select Counter.
              3. Select Present Parts Life.
              4. Select Fixing Web Cleaner and press Clear.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
