I have a KM 423 (150,000 on the clock) with an intermittent jamming problem (every 50 pages or so)
The jam is J 30-01 which points to the image transfer section but my problem seems to be deeper than that..
Each time the jam happens only from Tray One A4 (portrait orientation) and no other way,
Every time the jam happens I clear the paper and it tells me to re-size my paper in tray one (checked all machine/paper settings they are all correct)
when the paper is re-sized the job runs again but jams almost immediately and will continue to do this until the orientation of the paper is changed or the tray is switched..
now here is the bit i am getting stuck with, the parts i have changed on this machine are as follows:
Tray 1 and 2, Feed unit 1 and 2, The PRCB, Exit Section, Fixing Unit, Drum/Dev Unit, Entire Duplex Section, Main Motor (M1), CL1 and the Entire Tray 1 and 2 Drive Assembly's (including both the paper size detection assembly's)
i have also updated the Firmware but still no luck..
Any help guys?
Any help guys?
