Need Firmware Imaging Toolkit 2006
    • 8172
    Re: Need Firmware Imaging Toolkit 2006
    What firmware version have you written to the card? This is the latest version details.
    Latest Mass Production Firmware for the C550 Model
    1. Release version and download file name
    The newly released program version and download file name are as follows.
    [Release version]
    <C550 MFP controller firmware>
    Model
    Program Name
    Current Ver.
    New Ver.
    Program File Name
    Checksum
    Note
    bizhub C550
    MFP firmware
    GPY-R6
    GB1-R6
    A00J0Y0-F000-GB1-R6.exe
    CDBD
    [Download file name]
    C550_PRI_DLBT1300320EN.doc
    2. What changed
    Release of bizhub C550 (Special Program - Card Ver.GB1-R6 i-option2)
    The individual files in the card and the checksum are as follows.
    2.1. Revision of individual version Program nameFile nameChecksumNote
    BOOT:A00J0Y0-1E00-G00-05874C
    MFP controller subset:A00J0Y0-1F00-G00-7020E8
    MFP controller:A00J0Y0-0100-GB1-R64C2B
    MFP controller system: A00J0Y0-1000-GB1-R6----
    MFP controller print controller: A00J0Y0-3000-G00-JD----
    MFP controller print controller font: A00J0Y0-3F00-G00-44----
    MFP controller print controller Demo Page: A00J0Y0-3E00-G00-00----
    MFP controller MIO: A00J0Y0-5000-G00-00----
    MFP controller PSWC: A00J0Y0-5100-G00-10----
    MFP controller MIB IF: A00J0Y0-5200-G00-J2----
    MFP controller IPP IF: A00J0Y0-5300-G00-82----
    MFP controller OutSide controller IF: A00J0Y0-6100-G00-80----For Fiery
    MFP controller TCP/Socket: A00J0Y0-6300-G00-J4----
    MFP controller OPEN API: A00J0Y0-7000-G00-12----
    MFP controller operation panel: A00J0Y0-8000-GPW-R6----
    MFP controller PIC: A00J0Y0-8200-GC7-23----
    MFP controller CSRC control Body: A00J0Y0-8300-G00-80----
    Scanner: A00J0Y0-0023-G00-36364B
    Printer: A00J0Y0-0050-GCA-22DA27
    Panel CPUA00J0Y0-8900-G00-02----
    FAX board controller: 15LA-0040-G02-13-000F105
    Operation panel message data: A00J0Y0-8100-GFV-R6902B
    ADF: A01H0Y0-0024-GC0-124C4D
    Finisher (FS-517)A07R0Y0-00N1-GC2-227767
    Finisher (FS-518)A07P0Y0-00N1-GC2-03AE5E
    Finisher (FS-608)A07U0Y0-00N1-GC2-227767
    RUA07X0Y0-00R1-G00-1131AC
    ZUA07T0Y0-00H1-G00-02E8D4
    (Copy Protect)----14C6
    • bungapads
      • May 2009
      • 69
      Originally posted by Mick01
      Here you go
      I have to reset the C550 CE Password. No one knows what it is. I have the Took Kit. I have followed the Service Manual page 80-87 approximately. Bought brand new unformatted 128 meg Sandisk CF Card. But still i get a cryptic response when I put the CF card in and then start the main and sub switches. It says. "This is invalid Card." " Make sure the Card". That is all it says. I do not know how it could be invalid when I followed every single step. I have tried a couple times, each time starting over from the beginning from formatting the card using the Tool Kit (not windows). I have verified the version number of the alleged software. Not sure what else. Hope you can help.
      • bungapads
        • May 2009
        • 69
        I have this "
        A00J0Y0-F000-GCQ-J8(00)". I decompressed into a "bizhub" folder on c drive as directed and then opened the toolkit, etc. But it did not work. I do i get the latest version and then I can try that I guess?
        Thanks ROn
        [Release version]
        Model
        Program Name
        Current Ver.
        New Ver.
        Program File Name
        Checksum
        Note
        bizhub C550
        MFP firmware
        GPY-R6
        GB1-R6
        CDBD
        2. What changed
        • bungapads
          • May 2009
          • 69
          #19
          I also have version 2.5.3 of the ToolKit. Has this changed too? Can I use it with the new version below? Can you send me the new version below?
          [Release version]
          Model
          Program Name
          Current Ver.
          New Ver.
          Program File Name
          Checksum
          Note
          bizhub C550
          MFP firmware
          GPY-R6
          GB1-R6
          CDBD
          2. What changed
            • 8172
            #20
            1st does the imaging toolkit successfully write the firmware to your CF with out any errors?
            2nd what slot in the machine are you putting the CF card?
            3rd if all the above works format the CF card in Windows, set file allocation to default then format & try again.
