Konica minolta bizhub c220, problem with grey!
  • easier
    • Sep 2025
    Hi everyone,
    i have a problem, konica minolta bizhub c220 don't print grey but print violet.
    Have yuo got a solution or a reason?
    Thank's you!
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica minolta bizhub c220, problem with grey!
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • easier
      i've the manual but it doesn't solve the problem.
      • kingarthur
        • 1399
        perhaps if you post a sample, it might help
        • easier
          yes this is the scan of some grey but in the scansion the color look correct SKMBT_C22013080923310.pdf
          • easier
            maybe in this photo you can understand better the problem. The photo it's a little dark but you can see that the grey is pink or light violet
              • 15071
              • easier
                yes copier but nothing change
                • mo0651
                  • 1054
                  When you print the internal demo page does it happen???? How old are the Iu's? and drums?
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    If this is a print job related problem using the standard controller, ensure you are using the PCL driver if its a windows machine.
                      • 23010
                      Originally posted by easier
                      yes this is the scan of some grey but in the scansion the color look correct [ATTACH]21669[/ATTACH]
                      Did you take a monochrome scan? The only color in that scan is black.
                      • Papou
                        • Jan 2012
                        • 1
                        Have you try test page in sevice mode Haltone pattern?
                        • easier
                          i installed pcl but nothing change. I really don't know how i can do.
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            find that hard to beleive.
                            if you tested pcl and PS side by side even if the fault wasn't rectified there would be a very noticeable difference in colour output.
                            • easier
                              no there'isnt a very noticeable difference it's the same print.
                              I try to print by a usb pen direct in the konica and it print correct grey.
                              Than i explain another thing, i have in my office two desktop computer and one laptop, from the desktop pc whith cable net the print is pink not grey, but from the laptop with wifi when i print the grey it's correct. Why!!??
