c650 refuses to scan Gradation Adjust prints?!
  • Synaux
    • Mar 2012
    • 1224
    I cannot get this retarded machine to scan in the gradation prints after I installed a new transfer belt--it keeps prompting me with something among the lines of "scan error."
    Oddly enough, it will typically work on the first scan; however, any subsequent scans fail unless I re-stabilize.
    I cannot find anything amiss with the scanning assembly.
    Anyone have any ideas?
    Thanks!
  • Zeldaman
    • Mar 2011
    • 946
    Re: c650 refuses to scan Gradation Adjust prints?!
    Hi there!
    Had a similar problem no scanning of the gradiation pages, always "failed". After checking i adjust the A-3 tray (side to side) then it was OK. Hope this will help.
    Greetings...
    • kingarthur
      • 1356
      I had this on a C250, I had to go into tech rep mode & adjust the scan area
      • Synaux
        • Mar 2012
        • 1224
        Thanks guys, I don't know why I didn't think about the tray/scan area adjustments.
        Turns out that all the trays and the scan area are out of calibration (which is somewhat weird because I did all of the calibrations only about 6 months ago).
        I was able to do the gradation calibration; however, I had to literately place the prints on the platten crooked to get the scans to work because I didn't have time to tweak the trays today.
          • 23008
          I had a C353 with a bent scanner that wouldn't read the gradation prints. The problem was pretty obvious once I made a few copies. =^..^=
