Bizhub 363+FS 527 with sort as default
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Have this combo and they have Sort turned on by default with the finisher. The issue we have is with the Sort function on if they scan from the glass it will ask you if you wish to scan another page or Finish. If you don't press finish and just press start it will print out your 1st original and then do a 2nd scan and hold that until you press Finish or Start. So when the customer walks off or comes to do another job soon after they get a copy of that 2nd scan etc. Is there somewhere where you can switch off the multiscan from the glass with the sort function on or does the customer just have to live with pushing a few extra buttons when scanning only 1 page on the glass?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • 23008
    Re: Bizhub 363+FS 527 with sort as default
    I have a bizhub C353 with the same dilemma, and have not found a solution.
    The only way that I've found to disable the continuous scan feature is to turn of sort.
    Sort or not to sort? That is the only real question.
    • dallas
      • Jun 2008
      • 115
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        I'll give that a try. Thanks Dallas.
