Lost Network and Security Options in Administrator settings C550
  • vaskostz
    • Aug 2025
    1235971_10200569281377891_315148464_n.jpg <img>http://www.copytechnet.com/forums/at...id=21813&stc=1</img>
    This is happened when I turn DHCP off (Network settings / Auto input IP). After restart the machine, a network and security option disappeared :?
    HDD & Controller are okay. I dont use Fiery. Maybe it's something in Tech mode like "reset factory settings", but I cant find it?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Lost Network and Security Options in Administrator settings C550
    did you manually put an ip address in?
    did you turn off auto ip or network services off?
    This will take up to 5 minutes to come on display after rebooting the machine and longer for the fiery to come ready.
      • 23010
      Does your HDD still show as "Set" under options? I know of a few occasions where scanning and print functions were no longer available. I don't know why it became "UnSet" but it did, and did not re-occur. =^..^=
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        I've had this happen before on a few occasions. Sometimes after a couple reboots it will re appear after a few minutes. Sometimes it takes up to 5 or 10 minutes. It's just a random bug in the controller I guess.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • vaskostz
            I made about 20 reboots and waiting more a half hour after each - the same (network & security options are gone)!
            I'm desperate.
            Mr Spock
            I just turn "auto ip" on, but I shut off DHCP. I didn't' manually put an ip adress in.
            • Konicoz
              • Jun 2013
              • 62
              these m/c's are temperamental and take forever to load options, check if HDD is still set - try trouble reset / print out config check new IP details, try to browse to device and see if these options are available in browser - good luck
              Hey what ya doing? - just screwing around.
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                I'm desperate.
                Mr Spock
                If you are trying to Auto acquire an Ip address for the copier then you are using DHCP (which must be On/Enabled). If your network does not support DHCP then your copier will never get an address which means it will never be connected to a network and no network security. Configure the network settings manually and you should be all set.
                You didn't say why this is an issue? Was the machine working and stopped? Or is this a new install and you are having difficulties with the set up?
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
                • kmcopytech
                  • Dec 2007
                  • 141
                  Lost Network setting...hi hi!
                  You need perfoming a NIC erase or NVRAM reset
                  Good luck!!!
                  • vaskostz
                    Good luck!!!
                    How? (Sorry for the question)
                      • 23010
                      Good luck!!!
                      This is advice of "last resort" type. Try the easy stuff first. =^..^=
                      • kmcopytech
                        • Dec 2007
                        • 141
                        It's a special firmware for flash card.
                        • vaskostz
                          Where I can find to download that firmware? (sorry for the question again, I'm not tech)
