Drum Wrapping
  • dannysaunders
    • Oct 2012
    • 6
    [Jamming] Drum Wrapping
    We have had a rash of paper getting sucked up in the drum carriage lately, seems to be only on humid days and only on 2 sided copies. I have had 5 of these calls and it seems like each time something different fixed it. I check drum ground, Separation bias and clean everything. Has anybody else been experiencing this lately and what has been fixing it for you?
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Drum Wrapping
    What type of machine? I'm gonna guess it's 601/751 machines?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • minimerlin
      • 851
      Re: Drum Wrapping
      You gave the reason for the fault in your post...humidity! Usually along with poor quality and badly stored paper! Also it is helpful to let us know what machine you have a problem with. Help us save our crystal balls!
      Please do not PM me without asking first.
        • 14812
        Re: Drum Wrapping
        Wow, you have crystal balls? Do they clink when you walk? haha
        • Nwankwo lawrence
          Re: Drum Wrapping
          So difficult to install develop 450 with generic 35c-1 printer driver. All neceessary connetion i have done, but the machine refuses. I know its possible to connect. Maybe i must have lost few steps. If anyone have experience such case please let me know. I need a solution to the installation problem
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Re: Drum Wrapping
            Yeah, thats relevant to the original post.
              • 23009
              Re: Drum Wrapping
              Do we know what model yet? I'm guessing PRO 920/950 ...
              Do I hear clinking? =^..^=
              • dannysaunders
                • Oct 2012
                • 6
                Re: Drum Wrapping
                Give a newbie a break. It's on 601's mostly. I cant fix the humidity though, just wondering if you guys had some tips and tricks.
                • emujo
                  • Jun 2009
                  • 3009
                  Re: Drum Wrapping
                  Nwankwo..old Indian term for "head up his ass". Emujo
                  • dannysaunders
                    • Oct 2012
                    • 6
                    Re: Drum Wrapping
                    First side comes through perfectly flat, second side jumps into the drum claws.
                    • suomi
                      • Oct 2008
                      • 152
                      Re: Drum Wrapping
                      Try adjust separate voltage in transfer corona.
                      Check drum claw.
                      • CraigW
                        • Dec 2010
                        • 417
                        Re: Drum Wrapping
                        They have recently fixed those long running drum wrap issues.....
                        Konica Minolta 652/552.
                        The 7155 series had a good run, except they never resolved any of it's problem from day one. Roll the dice !
                        • scottybbb
                          • Dec 2010
                          • 126
                          Re: Drum Wrapping
                          Try moving the drum claw solenoid over to put claws closer to drum.On 601/751 you cannot move it very much but on the 920/950 series it can be moved.Has worked for me.
                            • 23009
                            Re: Drum Wrapping
                            On the 950 I've gone so far as to engage the drum solenoid all the time. Some paper still sneaks past, and you get broken drum claws too. There is a switch setting to keep the drum claws engaged the entire time the copy job is running, then disengage when the job is completed. I've gotten the best result from that setting. =^..^=
                            • methogod
                              • Dec 2008
                              • 921
                              Re: Drum Wrapping
                              you can set the paper to "PINK" or another color, which will help.
                              I have a few 920s that do this...
