Konica Minolta Bizhub 421
  • 978jose
    field Tech
    • Aug 2011
    • 19
    Hi, I have Bizhub 421 with 500k problem: when printing is OK, but when copying is like 2 inches black imaging. I already clean all optics components and the did not make difference.
    Any suggestions please
    Thank You
  • kingarthur
    • 1383
    Re: Konica Minolta Bizhub 421
    Thank You
    posting a sample of the fault might help
    • 978jose
      field Tech
      • Aug 2011
      • 19
      This what the machine doing it.
        • 23010
        Your drum is worn out. I believe this model gets maintenance at 250K intervals, so most likely a drum, developer, and maintenance kit are called for. =^..^=
        • 978jose
          field Tech
          • Aug 2011
          • 19
          I put new drum and developer, but i have the same. the problem is just when copying, if I print It is working good.
            • 23010
            How about the drum cleaning blade? Did you replace that too?
            I'm sorry but I have some doubts about your observations. The sample that you photographed is clearly a worn out drum, and the issue would not disappear on prints. =^..^=
            • 978jose
              field Tech
              • Aug 2011
              • 19
              [QUOTE=blackcat4866;377768]How about the drum cleaning blade? Did you replace that too?
              I'm sorry but I have some doubts about your observations. The sample that you photographed is clearly a worn out drum, and the issue would not disappear on prints. =^..^=[/QUO
              I know is weir but when I print or internal test page is comes out good. The problem is just when it is copying.
              • 978jose
                field Tech
                • Aug 2011
                • 19
                [QUOTE=978jose;377773]
                Yes Did replete the drum cleaning blade.
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  A drum would go to the edges of the page.
                  Does it do it on the glass or just doc feeder?
                  Do the optics move freely? Any abnormal noise?
                  • Mr Spock
                    Vulcan Inventor of Death
                    • Aug 2006
                    • 2064
                    Look closely at the top if image. There are digital lines mixed in. You are looking at one or more of the following: memory, ccd, system pwb, possible carriage but I doubt that. I would do firmware then the parts I listed in that order.
                    • 978jose
                      field Tech
                      • Aug 2011
                      • 19
                      Thank You very much. Other Tech and myself worked for 4 Hours yesterday. We put other PWB to try and nothing happens, other HVPS same thing. We check optics components and we didn't see anything abnormal (no noise). Today I'll check the optics systems again, I never had a problem with exposure lamp in those machine but I going to replace it just in case and going to work with firmware.
                      I let you if we find the solutions for this problem. Thank You again...
                      • JustManuals
                        • Jan 2006
                        • 9838
                        Paul@justmanuals.com
                        • 978jose
                          field Tech
                          • Aug 2011
                          • 19
                          Ok than you so much. We going to work on this today and I let you if we fix the problem thanks again...
                          • nvram
                            • Jul 2009
                            • 40
                            check mylars on front and back dev tank mag roller for perforations.
                            • 978jose
                              field Tech
                              • Aug 2011
                              • 19
                              Thank you nvram, but the problem is just when copying, not when printing. I think is in the optics but I couldn't find the problem yet.
