Jam 10-02 and 11-02 on bizhub C452
  • occus
    • 337
    Hi
    Have anyone experience about Jam 10-02 / 11-02 on a bizhub C452?
    It means i have paperjam from bypass and tray 1.
    (Manual:For paper fed from the tray1, due to a delay in paper arrival, loop forming in front of the timing roller is not complete before the rise timing of the registration motor)
    ...tray 2/3/4 works fine.
    I changed the Rollers, the sensors the cable tree, the clutch, paperfeed/transport control board.
    several adjustments with registration loop and tests with the pick-up pressure, nothing works.
    it's really a hard issue to resolve...
    Paper jams with a intervall around 20-40 pages A4
    have anyone ideas?
    thx
  • emujo
    • Jun 2009
    • 3009
    Re: Jam 10-02 and 11-02 on bizhub C452
    Try replacing A00J570711 (gear) and 57AA82030 (Clutch) for the affected tray. Emujo
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      sounds like the black 1 way gear for the vertical transport roller on the tray 1 feed unit has failed.
      I'm not sure if thats the part thats already been suggested - i dont have the part number off the top of my head.
      • occus
        • 337
        Thank you for reply!
        @emujo
        In my parts catalog i can't find A00J570711 (gear), Which gear do you mean?
        Your parts number is for the older series, c450/550/650, drive roller (black double roller vertical transport)
        the 57AA82030 (Clutch) i have already changed.
        @EarthKmTech
        You can specify the gear on my picture?
        It is really strange, because the vertical transport works well for tray 2/3/4...
        the motor for drive tray1 and tray2 is the same (belt and gears)
        -if i set the value for registration loop to -5(max) it works a bit better, the jam interval is longer.
        -i changed the sensors and the pickup-assy from the working tray2 to tray1, is always the same...
        from the bypass, sometime it looks like the machine reduce the speed and after the jam occurs. I know the machine have a speed control to save the space from sheet 1 to the next sheet, but which parts are involved for this control?
        Paper jams always on registration roller sensor / timing roller sensor
        I think both jams 10-02(bypass) and 11-02(tray1) have the same reason/bad part.
        From KM i get not really a good solutions... firmware update/ nvram reset, nothing works. And now i should replace the nvram but i don't think thats the solution.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          item 30 is the gear i'm talking about. its a 1 way spring clutch for the vertical transport roller.
          They fail all the time on high volume machines (~1M-1.75M max life expectancy on this part) i carry them in the car. Theres 2 of them and i change them as a pair. Same place in tray 2 feed unit. Be careful when assembling the feed units that the electromagnetic clutch holder goes back in the correct position. Dont remember if its 1 or 2 that is secured by the end plate but something to be aware of.
          • occus
            • 337
            Thank you for the hint
            I'll try it.
            The machine have 400'000 prints.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              I've never had one fail at that low page count.
              I suggest if this doesnt work just try a new tray 1 feed unit complete.
              • occus
                • 337
                I can't order a complete unit here.. ? only parts... you can?
                But you give me the solution!!
                The bad part is a clutch (Gear with a srping inside) but if you read the manual and the parts then you see only a gear...
                A00J574400 Gear 22T, thats really bad.
                I ordered all clutches to change but this part i had never seen...
                Now the machine runs and runs and runs
                thank you so much for your experience! @EarthKmTech
                best regards, occus
                • SAR
                  • Jul 2009
                  • 203
                  Having the same problems here. Please let me know if you find out what fixes this issue!
                  Thanks!
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Paul@justmanuals.com
                    • occus
                      • 337
                      read the my last post...
                      replace A00J574400 Gear 22T
