Bizhub 601 FS-524 Jamming--Stapled mode only, J7217 or 7218 Everytime
  • solidzdawg
    • 71
    Thread title says most, been working on this intermittent jamming when ONLY doing stapled sets. Machine always spits an error code of 7217 or 7218 ALWAYS... Machine has 1.5Mil on it, with only 165k staples.... I am running out of ideas, if someone could point me in the right direction It would seriously make my week!
    Things I have done:
    Checked Guide Sheets for knicks, burrs, paper marks---OK
    Replaced Bypass Gate Solenoid SD5
    Replaced Paper Exit Sensor
    Replaced Finisher Entrance Sensor
    Aligned Timing Belt with Cam on Stacker Unit
    Replaced Sponge Rollers that guide paper down into stacker
    I have scoured these forums and Google and havent been able to find too much, I found a thread on one of the codes but it didnt have much to say...
    This issue is kicking my ass, im sure someone here has ran into this?
    • 22999
    Re: Bizhub 601 FS-524 Jamming--Stapled mode only, J7217 or 7218 Everytime
    This was posted on the bizhub C600 with the FS-504 finisher, but I think you'll find that most of these KM finishers are very similar:
    It's jamming J7229 and J7217 but only to tray #1 of the FS-504 finisher, which is the print tray for this customer. Oh, and only after it has sat idle for an hour or so.
    The first visit I removed 1 jam, then ran 500 duplex pages to tray #2, the copy tray. Of course it didn't jam.
    After 6 visits the FS-504 made it back to the shop, and with some regular prodding we saw it jam a few times. Always after sitting an hour or more, always tray #1.
    It was pretty clear that the Nip Moveable Section (KM-speak for that mouth at the exit that cams open and closed as needed) was sticking in some way. We had cleaned and lubricated bushings, changed the solenoid that operates the "moveable" part, and it still did it.
    In between the lower surface operated by the solenoid, and the upper surface run by the cam and motor is a couple spongy sound damping pads that had gotten quite mushy and sticky. The resulting 1/2 second delay caused by the pads, created the stall condition at the exit. We just scraped off the pads. It doesn't even click when operating.
    I guess the important part of all this is that this basic KM finisher hasn't changed much in 10 years, so watch for this. =^..^=
    • solidzdawg
      • 71
      Thanks for the reply Blackcat
      While good to know, that's not the same issue I'm having... While it does only occur to tray 1 of this fs-524, it's only when sending staple jobs... Punching and straight thru tray 1 is flawless everytime..I'm gonna still look for those sound dampness, I just have to figure out exactly where those are located! ..
      I still feel pretty outwitted on this issue
      Has anyone ever had luck fixing intermittent finisher jams with a new fnscb? I have an extra one I'm gonna try tomorrow just to say I have.. That board controls a lot of the timings related to the stacking operation..
      -Z
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • Synaux
          • Mar 2012
          • 1224
          -Z
          • dave novak
            • Oct 2013
            • 10
            Maybe its the 2 one way gears on the front of the finisher, and shafts.
