bh c451
  • jackson007
    • Jul 2010
    • 114
    [CQ] bh c451
    there is a problem in c451, that in cyan imaging unit developer is reducing in middle of the unit.i relpaced 2 units for testing basis both units the same problem,erasing lamp is litting fine.what else my friends.costomer is not giving me time.so please
  • JustManuals
    • Jan 2006
    • 9838
    Re: bh c451
    paul@justmanuals.com
    • Blizzoo
      • Aug 2013
      • 608
      Re: bh c451
      Gave you chek and clean the Cyan Prinhead ?
      • jackson007
        • Jul 2010
        • 114
        Re: bh c451
        yes i cleaned ph unit with cleaning stick
        • emujo
          • Jun 2009
          • 3009
          Re: bh c451
          You need to pull the print head from the MFP and do some basic cleaning....Emujo
          • blaze2000
            • Sep 2010
            • 232
            Re: bh c451
            yeah man, toner and dev powder can lay on top of the PH. The cleaning wand may not move it all. Pull the IU's and shine your flashlight down through the slit that lets the PH unit hit the drum. Doing so will allow you to physically see if any debris is preventing the proper imaging. Did you replace or at least pull the transfer belt unit to see of maybe the cyan transfer roller is causing the problem? Good luck brother
