Bizhub C550 Solid Black Copies
  • Guy Milner
    • Nov 2013
    • 61
    [CQ] Bizhub C550 Solid Black Copies
    Hi.... We have a Bizhub C550 which intermittantly throws out completely solid black copies. Have tried numerous new K image units being replaced. By pulling out the unit and pushing back in, this normally gets it working for a while again. So, has anyone had connection or HV problems. Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub C550 Solid Black Copies
    paul@justmanuals.com
    • copier tech
      • 8174
      Did you ever find a fix for this? As I have the same issue on a 423!!??
      • Guy Milner
        • Nov 2013
        • 61
        We were lucky enough to have a donor machine, so we ripped out all the main units including the Print Head and MFP Board etc. Unfortunately we still get the occasional black copy....but it's a lot better than before !
        • copier tech
          • 8174
          Well I was lucky, I simply replaced the image unit & that fixed it, a week later it's still ok!
          • grimreeper
            • Apr 2014
            • 12
            We had a similar problem but our machine loosing developer and was not leaking developer was leaving the imaging unit K with the toner we did everything that you have done but ended up stripping the HV board out and cleaning all the cotacts and basically cleaning the machine thoroughly.
            I know major job but 8 months later the machine is still going strong PM issues only no funny issues. Good luck!
            • Synaux
              • Mar 2012
              • 1224
              Just a little not about the K IUs on these: There is a Black IU mod bracket sold for these (or you can simply put some paper/cleaning pad/rubber/whatever between the latch and the IU to make a more snug fit with the HV contacts
