biz hub 501 sc 2403
  • digicor
    • Jul 2008
    • 1159
    biz hub 501 sc 2403
    Biz Hub Blk N Wht 501
    Here's what happened,
    The toner needed changing, i used an after market bottle i had from another machine, then the code sc 2403 came right up, so i switched it the next day with OEM, not the code only comes up when the bottle rotates.
    The Bottle will rotate two or three times then code out., Is there is a reset or what, ive re set the hopper to its original position every time, then it rotates two or three times and then is codes.
    What now?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: biz hub 501 sc 2403
    Probably the toner rotation sensor. Try can of air/vacuum to clean it. Also check service mode to see if the sensor is working.
    • JustManuals
      • Jan 2006
      • 9838
      paul@justmanuals.com
      • CCS
        • 266
        Pull finisher/bridge, remove access plate, remove toner rotation sensor, clean sensor and re-install
        • digicor
          • Jul 2008
          • 1159
          where is the access plate? I have two metal covers, one over the toner hopper and one under where the finisher would sit,both have a lot of screws and dont come off easy
          There is no one screw access plate, can you send a diagram or pic?
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            From what I remember, there isn't really a one screw access plate. You do have to remove those covers in the area you describe. Wish I had a picture but I don't. There is no instructions in service manual either. LOL
            Good luck.
            • MVPunisher
              • 209
              Yea go do your load check and make sure that bottle turns properly. If so then yep good ole rotation sensor.
              500-420 was awful, disassmble back and front to get to those silly screws to remove the plate. (leave them off after lol) T
              I think he is right about an access plate on the 501 series. I think there is a hole to get your screwdriver onto the rotation sensor screw.
              As long as the bottle turns it will be that sensor though.
              • digicor
                • Jul 2008
                • 1159
                The bottle turns just fine,
                I tore up a parts 501 looking for this access plate, no can find. Must older versions, so im left with trying to clean the sensor from the toner bottle entrance.. I see a coat hanger and an alcohol swab in my future. if that dont work then ill tear the dam thing down to the ground.There is one stupid screw to remove the plate you have to get to from the back! all the rest come off from the top or side! Thanks KM
                • MVPunisher
                  • 209
                  I was cleaning them, then had a few callbacks and realized it was worth it just to replace. And I dont think tue new model had any diff plate. I think its the same plate it just has a hole for your screwdriver. Then u can take the left plate off and reach in. Pretty surr you can just keep that awful plate right on.
