Biz Hub Blk N Wht 501
Here's what happened,
The toner needed changing, i used an after market bottle i had from another machine, then the code sc 2403 came right up, so i switched it the next day with OEM, not the code only comes up when the bottle rotates.
The Bottle will rotate two or three times then code out., Is there is a reset or what, ive re set the hopper to its original position every time, then it rotates two or three times and then is codes.
What now?
What now?
