C284e sleep
  • fancheta
    • Oct 2013
    • 30
    [Misc] C284e sleep
    Im having a problem with a machine that can not wake from sleep. I would have to power cycle the machine to get it working again. A tech already modified the wake/sleep scheduled times but still having the same same problem. Does anyone know what else can be done?
  • occus
    • 337
    Re: C284e sleep
    firmware? !
    • fancheta
      • Oct 2013
      • 30
      Re: C284e sleep
      Originally posted by occus
      firmware? !
      fw is A5C10Y0-0100-G00-63
      • occus
        • 337
        Re: C284e sleep
        Good chance to fix this issue with a new firmware
        or read the existing threats about this well known issue in this forum.
        good luck!
        • fancheta
          • Oct 2013
          • 30
          Re: C284e sleep
          good luck!
          I'll try new fw. Its weird with these E series. So far every machine I've tried updating firmware, during the download process the MFP would get an N.G. while the other components would update. I've tried various usbs too and since the mfp didn't update, the machine would not blot anymore.
          • avecosat
            • Jun 2012
            • 305
            • manoj1686
              • Jan 2011
              • 22
              Re: C284e sleep
              TRY F/W GD1-A9 and will fix your problem for ever,
              There is a temperory solution:
              Pagescope web page ->Admin login -> Network -> SSDP setting -> OFF
              • bigdcopy
                • Dec 2010
                • 70
                Re: C284e sleep
                when you do a firmware update on the 4series first format your usb to fat32 then (the current firmware I use is GC8-70 this firmware solves about 250 different weird problems) copy all the files in the firmware folder (including the misc folder). Have a little patience I have had machines that would not update firmware what I did was start the procedure again including format and copy files and it would take the second time.
                • wseyller
                  • Sep 2012
                  • 1129
                  I just had an issue with rebooting every three seconds and had to replace ssd board to fix the issue.
                  Our regional manager at KM suggested to load special firmware on this machine and future setups.
                  Special firmware released 12/20
                  GD3-A9 Web Browser
                  GC3-A9 Non Web Browser
                  Sent from my DROID BIONIC using Tapatalk
                  • copier tech
                    • 8169
                    Re: C284e sleep
                    I have not been able to get any C284 or C284e to boot from the USB, I have formatted it & copied the FW folder contents to the root of the USB but it just won't take the fw. Do I need to copy the contents of ALL the folder to the root of the USB!?
                    I'm using a 4GB USB pen drive & this works fine on the C280 & C552 etc.
                    • TheOwl
                      • Nov 2008
                      • 1732
                      Re: C284e sleep
                      Before replacing anything, make sure that Fax Circuit 2 is disabled from service mode (unless you actually have a 2nd Fax Line).
                      I had this ages ago on a C224 and I replaced the HDD, MFD and SSD boards and didn't fix the issue.
                      Chances are that is could be the HDD as Konica Minolta were working on the Fax Circuit 2 issue, but just in case, I would check it first.
                      • ni311
                        • May 2008
                        • 658
                        Re: C284e sleep
                        You are using the pen drive with the wrong size. The size of the usb stick has to be up to 2 Gb. I was trying to update with a 4 Gb stick and didn't work but with a 1 Gb stick worked just fine. Remember to use the service port when updating the firmware. You don't have to copy the contents of all folders in the root.
                        Konica Minolta Error Codes - Explanations and Solutions
                        • copier tech
                          • 8169
                          Re: C284e sleep
                          Thanks, but strange how the same 4GB USB pen works on older models!?
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            Re: C284e sleep
                            FAIL
                            • wseyller
                              • Sep 2012
                              • 1129
                              It is hit or miss. I have sone 8GB USB drives that I flash firmware on these models. Out of the 20 or so USB drives I carry around with me I will find one that works.
