Im having a problem with a machine that can not wake from sleep. I would have to power cycle the machine to get it working again. A tech already modified the wake/sleep scheduled times but still having the same same problem. Does anyone know what else can be done?
C284e sleep
Re: C284e sleep
I'll try new fw. Its weird with these E series. So far every machine I've tried updating firmware, during the download process the MFP would get an N.G. while the other components would update. I've tried various usbs too and since the mfp didn't update, the machine would not blot anymore.Comment
Re: C284e sleep
when you do a firmware update on the 4series first format your usb to fat32 then (the current firmware I use is GC8-70 this firmware solves about 250 different weird problems) copy all the files in the firmware folder (including the misc folder). Have a little patience I have had machines that would not update firmware what I did was start the procedure again including format and copy files and it would take the second time.
I just had an issue with rebooting every three seconds and had to replace ssd board to fix the issue.
Our regional manager at KM suggested to load special firmware on this machine and future setups.
Special firmware released 12/20
GD3-A9 Web Browser
GC3-A9 Non Web Browser
Sent from my DROID BIONIC using TapatalkComment
Re: C284e sleep
I have not been able to get any C284 or C284e to boot from the USB, I have formatted it & copied the FW folder contents to the root of the USB but it just won't take the fw. Do I need to copy the contents of ALL the folder to the root of the USB!?
I'm using a 4GB USB pen drive & this works fine on the C280 & C552 etc.Let us eat, drink, and be merry, because tomorrow we may die!
Re: C284e sleep
Before replacing anything, make sure that Fax Circuit 2 is disabled from service mode (unless you actually have a 2nd Fax Line).
I had this ages ago on a C224 and I replaced the HDD, MFD and SSD boards and didn't fix the issue.
Chances are that is could be the HDD as Konica Minolta were working on the Fax Circuit 2 issue, but just in case, I would check it first.Please don't ask me for firmware or service manuals as refusal often offends.Comment
Re: C284e sleep
I'm using a 4GB USB pen drive & this works fine on the C280 & C552 etc.Comment
Re: C284e sleep
Thanks, but strange how the same 4GB USB pen works on older models!?Let us eat, drink, and be merry, because tomorrow we may die!
