FK502 C353
  • mrfuser
    • 1622
    FK502 C353
    Do you know if the FK502 fax kit is the same on the C352 as on the C353?, or is the FK502 the same for all FK502 kits regardless of machine installed into?
    Kelly
  • ck1
    • 485
    Re: FK502 C353
    As i know is Fax board is same , only the mount kit too bad
    • Synaux
      • Mar 2012
      • 1224
      Re: FK502 C353
      What?
      • JustManuals
        • Jan 2006
        • 9838
        Re: FK502 C353
        Originally posted by Synaux
        What?
        It sounds to me that the board is the same across machines, but the mounting kit is different. That's what it sounds like to me anyhow. My $.02 cents FWIW. (For what it's worth)
        HtH
        Paul
        • ck1
          • 485
          Re: FK502 C353
          What?
          The fax dard same as C250 , onlt the mount kit ....
          • Hansoon
            • Sep 2007
            • 3389
            Re: FK502 C353
            One could McGyver a box or similar support for the fax kit FK-502 but the problem is that interface board which is in the mount kit MK-711........
            Hans
            • copytechman
              • Nov 2008
              • 947
              Re: FK502 C353
              Will confirm, a C203-253-353 series machine requires the MK711 mount kit (which has 2 slots, for fax or usb) needs to be installed on the back of a c353 series for fax to function. The FK502 itself is the same across the board. Only the mount kits typically differ.
              Regards!
              A.
              • emujo
                • Jun 2009
                • 3009
                Re: FK502 C353
                Does anyone else think it's funny that this poster can't understand what the previous poster said.....I'm sorry, if this is the best you can do with typing, then I automatically put you in the "moron" category. Emujo
                  • 14812
                  Re: FK502 C353
                  What's wrong? Who hasn't wanted to mount a fax dard at some point? Olnt, make sure nobody sees you. lol
                  • ck1
                    • 485
                    Re: FK502 C353
                    Just wrong typing and not checking only ... I know your eng very GOOD.....
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      Re: FK502 C353
                      The actual FK-502 fax cards are all the same, no matter what machine you put it into or it come from ensure you flash the firmware prior to starting to using it.
                      I keep one in the car from a wrecked machine at all times for testing purposes.
                      If you're talking about mount kits well no, they're very very different and specific to the engine your intending to install it into
