C253 Life Stop Help!
  • copier tech
    • 8172
    [Misc] C253 Life Stop Help!
    1. Life warning of low toner is NOT displayed.
    2. DipSW No.51 0x00 : Life warning is displayed. (Default)
    3. DipSW No.51 0x08 : Life warning is not displayed. I WANT TO SET THIS ONE
    2.Life warning of Image unit is NOT displayed.
    DipSW No.51 0x10 : Life warning is not displayed. AND THIS ONE
    So what switch do I need to change, I understand the DipSW number,
  • solidzdawg
    • 71
    Re: C253 Life Stop Help!
    8 bits to a byte.
    When you look at the DipSw editing screen there will be 8 numbers in one row representing your bits either set to "0" or "1".
    Count down from 8 left to right (example below) to learn their positions. this is crucial to know because you need to know which bit(s) to set to 1 or 0
    8-7-6-5-4-3-2-1
    But it will look like this on the screen
    0 0 0 0 0 0 0 0
    The manuals will tell you which bit to turn on to "1" or "0", now you know the positions in which they speak of.
    I hope I didnt confuse you, sorry if i did This is pretty basic stuff though..
    • kingarthur
      • 1369
      The easiest way is to just change the "hex", change switch 51 to "D0" and 55 to "0C", dont forget to press "FIX" after changing each one
        • 14812
        51- 1101000 fix
        55- 00001100 fix
        53- 00000001 fix
        • copier tech
          • 8172
          Bizhub C203-c253-c53-c451-c550-c650 End of life.pdf
          Thanks for the info, but can someone explain the attached file, it shows the software BIT switches as 7 6 5 4 3 2 1 0 so there is no "bit 8"
          Or was this just on the older models?
          But I understand it's easier to simply set the HEX box.
            • 14812
            [ATTACH]24199[/ATTACH]
            Correct, there is not a bit 8. Just set them as I typed them, it doesn't matter how they are numbered.
            • kingarthur
              • 1369
              51- 1101000 fix
              55- 00001100 fix
              53- 00000001 fix
              Why are you changing softswitch 53, when it's not mentioned in the bulletin.....and there are 8 bits....7 all the way down to and including 0
                • 14812
                I said there is not a Bit 8. I didn't say there weren't 8 bits.
                Soft switch is for ACS (auto colour selection). It stops the colour drums from turning when they are not needed.
                • docdot69
                  • May 2016
                  • 53
                  i have bizhub c253 and the machine yield for drum K, but i dont want to replace it. Just thaught i can manage it by soft switches 55 and 51, but even if i fix them after changing, the setting is not remembered. Is there any special firmware allowing to change soft switches 55 to hex:0C and 51 to hex:F0?
                  • copier tech
                    • 8172
                    Yes there is special firmware for this, however simply updating to the latest version will allow you to fix the settings.
                    You also have the HEX settings wrong, should be 51= D0 55=0C
                    • docdot69
                      • May 2016
                      • 53
                      You mean G20-R6, latest mass production firmware available on infohub will allow to make soft switch changes?
                      51 hex D0? on bizhub c220 and after, hex F0 is making no yield even for iu or transfer belt.
                      • Oystercopy
                        • Oct 2009
                        • 623
                        You need later F/W to allow you to make the changes to the softswitches, otherwise they'll never let you hit "Fix" and stay where you set them.
                        Also, the latest bulletin shows exactly which softswitches/changes in service mode need to be changed for that particular model. If you need the bulletin,
                        I'll try to figure out how to upload it here...??
                        OC
                        • copier tech
                          • 8172
                          Yes, simply load the Mass production firmware from Info Hub then you'll be able to change the HEX settings. 51-D0 55-0C
                          • docdot69
                            • May 2016
                            • 53
                            latest mass production f/w: G10-R6 - still can't fix those switches....
                            • docdot69
                              • May 2016
                              • 53
                              OC
                              have you got any special firmware for this problem? i tried a few from infohub, bot still don't work...
