Bizhub C351 Error C-3452
  • RichGK0215
    • Jun 2008
    • 17
    Does anyone know what Error C-3452 means on a KM Bizhub C351? I am checking everything right now as we speak, but wanted to get any help that I can. I greatly appreciate it.
  • stacyrf
    • May 2008
    • 40
    that is a fuser code my friend. pressure roller not warming up. my experience with these is, it's not worth tearing the fuser apart to replace/clean the thermistor. Just replace the fuser.
    • RichGK0215
      • Jun 2008
      • 17
      OK, thank you. I just replaced the fuser yesterday and it worked for about 30 minutes while we printed and then it stopped. Maybe its a bad connection or the fuser is bad. Any ideas on that?
      • stacyrf
        • May 2008
        • 40
        stopped with the same code? If so, yes 1 of 2 things could be wrong.
        1. could be like you said, a bad fuser
        2. reseat all the connections on the board (this is what I would do first)
        • RichGK0215
          • Jun 2008
          • 17
          OK, thanks. I am going to take it out and re-install it and see if that works. THANKS AGAIN!!!
          • fshead
            • 2376
            Re: Bizhub C351 Error C-3452
            ok i googled this post and have ONE bishub i see maybe every 2 years..
            im a mostly ricoh tech although i was trained and serviced the full minolta line
            before digital became the norm.
            i see the lower "pressure" roller is not coming up to temp from post.
            i cant even remember how this fuser lays out..
            do i have to reset the fuser code thru service mode 1st like in the ricohs?
            this machine about how many years old now?
            8 years?
            thnx
