Corrupted Fiery Controller
  • Ricadob18
    • Aug 2025
    [Dead] Corrupted Fiery Controller
    Hi guys.
    Please my c6500 controller is corrupt and won't come up on the display screen.
    I have the IC-408 software but whenever i try to run it it displays "insert disk 1".
    Please what do i do?
    All 4 machines have the exact same controller problem.
  • jotunn
    • 618
    Re: Corrupted Fiery Controller
    Call for service...
    If you have trouble installing software on 4 controllers - it's not a problem with your controller but with your software or the way you are trying to install software.
    Try to use pendrive for installation - you need to get USB Prep Tool 1.3.1 or higher, and using this tool create bootable pendrive for system installation.
    • TheOwl
      • Nov 2008
      • 1732
      We actually have a clone of a working controller and find that it is normally quicker to simply re-image the drive with the clone we made from Acronis.
      If you have a good machine in the field, ask the customer if it is ok to pull it offline for an hour and go out there and make a clone of the Fiery HDD. You can then use that to get your other machines running again, but don't forget to re-setup the Fiery as cloning another clients will transfer their settings to the other Fierys.
