Cleaning Transfer Roller?
  • Synaux
    • Mar 2012
    • 1224
    Just looking for some tips here. Especially with environments with medium print counts, but mostly high coverage rate on c550/650s the transfer roller gets gummed up every ~25k (especially in the middle on the roller).
    This affects CQ.
    While I simply go there and vacuum it of and take a soft rag to the middle to gently rub some of the white residue off. I would like a longer lasting solution.
    Alcohol, Water, Acetone, Hydrochloric Acid? What do you guys do?
    Also, I was thinking that perhaps in high coverage environments to kick up the primary/secondary voltages a bit to clean up errant toner getting on the transfer roller. Would this help?
    Paper is good quality and the rollers are mostly below half life.
    Thanks!
    • 14791
    Re: Cleaning Transfer Roller?
    I definitely wouldn't use a rag on them. The most I would do is blow them off with canned air. You may just need to replace them a little more often.
    • Hansoon
      • Sep 2007
      • 3389
      In the shop we soak them first with clean water, than use water with a very little detergent to wipe them off with a sponge. Rinse with lots of water under a running tap, blow them dry with air and continue to dry near a heater. I carry always a "pre-treated" used roller for every model in my car.
      Hans
        • 14791
        Hans
        Sounds like a lot of labour to save a couple bucks. lol
        • Hansoon
          • Sep 2007
          • 3389
          What do you call a "Couple Of Bucks"?
          Hans
          • Synaux
            • Mar 2012
            • 1224
            Hans
            That is fascinating!
            Could you be a little more specific on the detergent you typically use?
            I have an old backup roller that is past EOL but was working okay before replacement. I will give it a shot.
            Probably not if you want to save $112.95 (Precision Roller). If you take 1 hour to clean up 5 transfer rollers you can consider that as paying yourself $564.75 per hour (if they last long enough).
            Not to belittle you, but people really should strive to stray away from this throw-away-culture mentality that materialism has deluded many with.
            Any other thoughts?
            What about increasing the voltages to make it run cleaner?
            I understand that the voltages alternate between a positive and negative current for better cleaning like the transfer belt does...would increasing the voltages affect the positive and negative?
            "To remove residual toner off the surface of the 2nd Image transfer roller, a +/- DC bias is
            applied alternately to the roller, thereby moving the residual toner to the surface of the
            transfer belt.
            The cleaning brush then scrapes off the toner on the surface of the transfer belt."
            (c650 Theory of Operation, p.85)
            Or would boosting the voltages be overridden by the ATVC (Auto Transfer Voltage Control) for this purpose (or always/never)?
            • Hansoon
              • Sep 2007
              • 3389
              Just good ol' dishwashing liquid.
              Hans
                • 23009
                I'm with Hans on this. The key to the whole procedure is installing a dry transfer roller. If you try to do this on-site it can take hundreds to a thousand prints to dry out the roller using the bias current. Personally I use water or non-ammonia glass cleaner. It does resolve eventually, it's just hard to explain to the customer that the copies will look good next week. And if it's color, you won't be able to do a good calibration.
                Alcohol or any of the oil based cleaners are damaging, and you may never get all the oil back out, giving you blotchy images until you replace it.
                • emujo
                  • Jun 2009
                  • 3009
                  Most of that residue is from cheap paper, anything more than 25% recycled will cause the roller to wear out significantly faster than its normal life span. Indicating the paper is "Recycle" will change the x-fer voltages accordingly and you might see a better return. Emujo
                  • jotunn
                    • 618
                    I can confirm Hans' method - we are using reconditioned rollers for second hand, leased or contracted machines for several years. For good results we use paint brush instead of sponge, then when all surface is wet and foamy we use our hands and we treat/handle roller like a sponge - squeezing out (I don't know proper word) all messy water with detergent, then repeating operation until roller is clean and rinsing detergent with clean water. Then we are keeping them day or two in warm place to dry.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Thanks for all the replies. I tried this and it worked fairly well even with a old ragged roller (I was unable to get all the middle residue off, but works like-new for the moment).
                      This might very well be a stupid question emujo, but I searched all the manuals for these machines and don't see any recycle setting...for bypass I get plain, sing side only, transparency, special paper, thick 1-4, duplex 2nd side, letterhead, colored paper, and envelope. Out of those I am think colored paper would be the only useful setting.
                      On this note, the paper types are specified by g/m--is there a way to make it display value in # when you select a paper type?
                      • emujo
                        • Jun 2009
                        • 3009
                        from the copy screen, go into the tray settings, "recycled" should be a choice. I don't believe you can set a paper type in user/admin/service modes. Emujo
                        • copier tech
                          • 8169
                          It sounds bizare to wash transfer rollers but i've been doing it for years on Canon & KM.
                          But obviously you need to make sure they are bone dry before fittting.
                          I would leave a spare one for your customer to fit as they only unclip easy for any customer to fit!
                          • Synaux
                            • Mar 2012
                            • 1224
                            Hmmm...I dont see it on the c550/650s here.
                            I guess my eyesight is worse that I thought.
                            • CompyTech
                              Super Tech
                              • Feb 2011
                              • 706
                              Hans
                              Interesting. I rarely clean them, but I have cleaned them on site with just a damp cloth or just a dry wipe.I replace when worn or maintenance cycle due, but I will consider this for future reference.
                              Thanks.
