My Network Settings choice on display screen is missing. Everything else is fine, can even print out configuration page. Need to input new addresses so it will print. Any help Thanks
Konica Minolta C-203 Network Settings
Tags: None
Re: Konica Minolta C-203 Network Settings
Where do you find the controller value in the service mode? Is NIC reset the normal trouble reset using utility key and power up procedure? ThanksComment
NIC reset must done with nvram recovery tool,must put on CF like a firmware update.
To view controller setting go in service mode->system 2->image controller setting.
Good luckDefects are simple, our mind is complicatedComment
Blizzoo The Image Controller Setting is also missing on my display screen. Where can I get a NVRAM recovery tool? Looks like I could use some luck. What next Thanks BuddyComment
The Image Controller Settings is also missing on my display screen. Where do I get the NVRAM restore tool? Thanks again BuddyComment
