Konica Minolta C-203 Network Settings
  • Buddy with ACR
    • Sep 2011
    • 13
    [Electrical] Konica Minolta C-203 Network Settings
    My Network Settings choice on display screen is missing. Everything else is fine, can even print out configuration page. Need to input new addresses so it will print. Any help Thanks
  • Blizzoo
    • Aug 2013
    • 608
    Re: Konica Minolta C-203 Network Settings
    Check if you have the correct Controller value in service mode 0 ->standard controller/ 1-if you use a firey
    Try a NIC reset.
    • Buddy with ACR
      • Sep 2011
      • 13
      Try a NIC reset.
      Where do you find the controller value in the service mode? Is NIC reset the normal trouble reset using utility key and power up procedure? Thanks
      • Albonline
        • Sep 2008
        • 1151
        do you have a service manual? the info you are looking for is in it!
        • Blizzoo
          • Aug 2013
          • 608
          NIC reset must done with nvram recovery tool,must put on CF like a firmware update.
          To view controller setting go in service mode->system 2->image controller setting.
          Good luck
          • Buddy with ACR
            • Sep 2011
            • 13
            Good luck
            Blizzoo The Image Controller Setting is also missing on my display screen. Where can I get a NVRAM recovery tool? Looks like I could use some luck. What next Thanks Buddy
            • Buddy with ACR
              • Sep 2011
              • 13
              The Image Controller Settings is also missing on my display screen. Where do I get the NVRAM restore tool? Thanks again Buddy
