converting 220v c350 fuser to 120v fuser
  • richwalker
    • Mar 2013
    • 30
    Hi all,
    Just checking if any of you brilliant techs have ever converted a 220v c350 fuser to be used in a 120v c350 mfp. I've got a customer that needs a fuser replaced and I've seen a couple of them under $300 on the web, but 220v fuser. I was thinking I could swap the connectors on the fusers to make it work.
    Cheers,
    Richwalker.
  • richwalker
    • Mar 2013
    • 30
    Re: converting 220v c350 fuser to 120v fuser
    If anyone has a used fuser (120v) that I can get/buy with the thermistors intact that would be great.
    Richwalker.
      • 23008
      It's my understanding that it's the heat lamps that use either the 120Vac or 220vac. So if you kept the original modular connector, wire harness and heat lamps, you should be safe.
      • richwalker
        • Mar 2013
        • 30
        Thanks blackcat4866, thought about that but wasn't sure if the connectors were a factor or not. I'll get the 220v unit and swap out the lamps as it's the thermistor that's broken on the unit.
        richwalker
        • ck1
          • 485
          richwalker
          If you machine is konicaminolta ( not oem like oce or etc ) .you can direct install. i have few unit from US version i just install 220v ok ( my location is 220V area ) . maybe you can try chk the PU auto convert or not .
          • copier tech
            • 8165
            Bit of a gamble this one & unnecessary, surely you can find a cheap 120v fuser online cheap somewhere!!???? even ask on this site!
            http://www.copytechnet.com/forums/fo...ade-or-wanted/
            • richwalker
              • Mar 2013
              • 30
              Thanks all for the tips and suggestions. I bought a rebuilt unit online for less than 200. Got it 2 weeks ago and installed it in the C350 and it's all good now.
              Thanks again for all the help.
              Richwalker.
