Bizhub c224e, FS533 (internal finisher) stacking/offset sort issue.
  • copytechman
    • Nov 2008
    • 926
    Re: Bizhub c224e, FS533 (internal finisher) stacking/offset sort issue.
    Originally posted by rrrohan
    wonder if the paper is getting stuck together causing it to struggle to pull it back in alignment with just a few short rotations of those mylar strips?
    maybe try some good quality paper like Mondi and see if that helps
    Thanks for that. Did that first thinking maybe it was cheap paper. Nope. Pulled it to my office to try on another 224, same issue. I yoinked it apart yesterday and still see nothing directly.
    Regards! A.
    • copytechman
      • Nov 2008
      • 926
      Originally posted by EarthKmTech
      all 4 series machine 224-454 have trailing edge paper curl in certain environments, I wonder if this is the cause.
      Ah yes, checked for that too by running plain paper as thick 3 or 4 to see if I could make it curl more and increase/decrease the symptom. Sadly there was practically no difference in how often it would occur!
      Regards!
      A.
      • MVPunisher
        • 209
        Any light shed on this problem>?
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          #19
          About the only problem I've had with these finishers is that silly little black actuator in the center of the exit flipping and causing the paper not to be able to be pulled back at all. It also has a rubber strip stuck on it that starts to bunch up and buldge at the end, could this be whats catching your sheets ?
          • MVPunisher
            • 209
            #20
            I figured it out this morning right after I posted but yes you were spot on...
            • copytechman
              • Nov 2008
              • 926
              #21
              Spot on regarding the piece he mentioned? Regardless, as an update I eventually got km involved and they couldn't spot anything odd either. It was ultimately rma'd.
              Thanks much !
              A!
