Bizhub 4050 sleep mode issues
  • SmellsHot
    Head Tech
    • 512
    I have a dozen of these puppies in the field that are having the same issue. Anyone find any tricks on how to wake these damn things up from sleep mode? I've maxed them out to 240mins, but I just wish I could shut the damn sleep mode off. All of my customers are frustrated with trying to wake these things up. I also noticed when going through settings, that the weekly timer is enabled on all new Konica equipment M-F 10pm-5am.
    Anyone else seeing problems with this model or with sleep mode on any of the newer Konica gear?
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
  • Ziggy
    • Feb 2018
    • 813
    Re: Bizhub 4050 sleep mode issues
    As far as sleep mode you first have to go into service mode and allow the admin to make the choice to turn off sleep mode. as far as the weekly timer goes it is set enabled by default but can be disabled.
    • REGSIS
      • May 2016
      • 440
      Yeah, you can disable sleep mode, but first try just to turn off weekly timer and nothing else. Operation panels fails a lot on this model, I wouldn't recomend leaving it ON for long, just in case.
      Sleep mode 15 min
      Enter power save NORMAL
      Power consumption in sleep mode ENABLE
      Sub power switch LOW POWER
      • Bix
        • Apr 2018
        • 1421
        I had this problem for a while. For this, I have set the maximum (but only 60 minutes). They did not complain.
