top to bottom lines (vertical)on anyprint
  • jackson007
    • Jul 2010
    • 114
    [CQ] top to bottom lines (vertical)on anyprint
    hai ,
    At our costomer place in bh c224e getting copy like attachment below.that is like verticalines ,top to bottom ,at every one mm white lines are coming vertically.plz tell me solution for that.
    enlarge and see.
    • 23009
    Re: top to bottom lines (vertical)on anyprint
    Can you be more specific about the direction of those lines? Vertical/horizontal means nothing, because the paper can be fed A4 or A4R.
    Please choose from :
    Feed direction/Crossfeed direction
    Main Scan/Sub Scan Direction
    Or you can just mark the feed direction on your sample. =^..^=
    • jackson007
      • Jul 2010
      • 114
      sir its a4
      a4/a3 ,lines will appear as top to bottom( sub scan)
      • jackson007
        • Jul 2010
        • 114
        try any body plz
          • 23009
          Originally posted by jackson007
          sir its a4
          You're two statements conflict.
          If the scanned image is A4, the voids are Main scan not Sub scan.
          I'm going to assume that they are main scan voids. How many clicks on the black developing unit and drum? It could be either one ... more likely the drum. =^..^=
