C552 Service mode password
  • cayyell
    • Feb 2013
    • 85
    Hi
    I have C552 where is service mode password, I have tried 92729727 but no luck.
    Now i have gotten NVRAM Reset tool, but according to the manual i still need to enter the service mode before NVRAM reset to disable some license stuff.
    Now how can I get this to work?
    I have done on C352 to removed the service mode password with its NVRAM reset tool, can anyone help me please?
  • copier tech
    • 8164
    Re: C552 Service mode password
    92729727 is the wrong password. Its 92729272
    however the C552 doesn't have a password set as default
    โ€‹
    • rrrohan
      • Sep 2011
      • 1977
      Pretty sure all recent models have CE authentication turned on by default
      • cayyell
        • Feb 2013
        • 85
        Sorry copier tech my bad is was 92729272.
        it won't work, is there any way to disable it?
        got the NVRAM reset firmware but instruction said need to disable the license before reset.
        any help please.
        • rrrohan
          • Sep 2011
          • 1977
          Are your sure its even got a
          Iicence installed?
          • cayyell
            • Feb 2013
            • 85
            Iicence installed?
            Hi,
            I m not sure, how can i verified that?
            I m used to C352, but not this C552
            2) Set software switch setting.[System2] -> [Software Switch Setting]
            Switch No.: 10
            Hex Assignment: 00
            [Note] Never forget to perform this step. If you perform subsequent steps without performing this step,
            license management error occur and you cannot repair it with repair code.
            This is what i get in the NVRAM reset tool documentation
            • stevena86
              • Oct 2012
              • 130
              Try 12345678 or 00000000?
              • cayyell
                • Feb 2013
                • 85
                hi,
                thx for the suggestion, but it won't work :P
                • Phrag
                  • Oct 2012
                  • 417
                  I don't suppose you've tried 9272?
                  • cayyell
                    • Feb 2013
                    • 85
                    Nope I don't, and I just tried won't work also
                    • rrrohan
                      • Sep 2011
                      • 1977
                      CE password has to be minimum 8 characters long
                      how did it get changed? is this a 2nd hand machine
                      if you dont know the CE password you dont really have any choice but to just run recovery regardless of licence or not then cross that bridge if you need to
                      • cayyell
                        • Feb 2013
                        • 85
                        Ya is a secondhand unit.
                        If anything happen to the licence won't the machine not working anymore?
                        That's a dangerous bet
                        • supertype
                          • Sep 2012
                          • 31
                          try 1234567812345678 can't remember if that's for the new line or the last series
                          also if no password is set it will still ask you to press ok
                          • rrrohan
                            • Sep 2011
                            • 1977
                            thats administrator mode not service mode
                            1234567812345678 is only the new models. its twice as secure lol
                            they did the same for the CE password but this is a old model so it should just be default
                            OP: have you contacted the person you purchased machine from for password?
                            Why not ask the customer if machine could OCR, if not then chances are it had no licence kit and your worrying about nothing
                            • cayyell
                              • Feb 2013
                              • 85
                              so the licence is for OCR? I m not sure, previous owner I half of the earth away from me and i do not know them for sure, I guess I can go on with the NVRAM Reset and give it a try?
