BH C452 drum reset chip
  • Desert Rat
    • May 2008
    • 1089
    I have to ask this, I think I know the answer. Can that device be re-used on another
    Set of drums?
    I'm thinking No.
    DR
    • 14736
    Re: BH C452 drum reset chip
    What device are you asking about?
    • copier tech
      • 8156
      Yeah what's your question?
      but all you have to do is update the firware then you never to to buy the chips
      • Desert Rat
        • May 2008
        • 1089
        I am asking if the drum reset for the drums can be used more than once?
        Actually I would like to have that firmware upgrade.
        DR
        • copier tech
          • 8156
          Once you turn on the iu disable message you will never get the "replace iu" message.
          So any IU will run in that MFD
          • Desert Rat
            • May 2008
            • 1089
            copier tech,
            Thank you for the help. As it turns out I got my chips and models mixed up.
            I was think that the chip reset device for the BHC360 was for the C452.
            That's where I was confused.
            Still I would like to have the newer firmware. Anyone care to share?
            DR
