Error code C2163/4 on biz hub C552
  • kamoga
    • Jun 2013
    • 36
    [Error Code] Error code C2163/4 on biz hub C552
    Dear all
    I have an error code C2163 and C2164 on bizhub C552
    I have tried changing the black drum ,also I have tried changing HV1 and he PRCB
    but all have no worked some help
  • kamoga
    • Jun 2013
    • 36
    Re: Error code C2163/4 on biz hub C552
    some help if there any one who has ever face any challenge like that
    or any suggestion or advice
    • acsolutions
      • Jun 2010
      • 519
      Did you ever resolve that error code? I just got that code and I guess I'll start with a drum unit maybe the developer also!
      • hooman23
        • Jul 2014
        • 57
        Originally posted by kamoga
        Dear all
        I have exactly the same problem with c552. And i replaced yellow image. Hv1 and prolinter control board .anny sujestin
        • hooman23
          • Jul 2014
          • 57
          Any suggestion. Does anyone have experience in this problem?
            • 23010
            Have you checked the high voltage contacts for corrosion or arcing? Have you ran a system error clear? Otherwise, you've covered most of the possibilities.
            • hooman23
              • Jul 2014
              • 57
              If i disconnect this connector system starts without any errors.but it has problem in yellow color. by the way my erorr numbers are c2164 and c2162. Yes i used system clear. An i didn't check connector with any electronic devices but im going to. The table no have strange code line in yellow
              • Synthohol
                Certified Konica Expert
                • 5894
                check the fuser and or the IC chip as well.
                i had one years ago that kept popping the IC chip for the fuser giving a fuser code.
                2 fusers and 2 boards later we discover the IC chip is shared with one of the fuser circuits and it was a bad DV unit not the fuser.
                i wonder if your situation is the same but reversed?
                id trace the IC fuse and test it. it may be shared with something else causing the code.
                on bootup the code would come up and fry the IC immediately.
                good luck.
                • hooman23
                  • Jul 2014
                  • 57
                  good luck.
                  IC chip you mean yellow imaging unit chip.? I replaced yellow imaging unite with another one. It throws c2164 and c2162 immidiatly
                  • hooman23
                    • Jul 2014
                    • 57
                    If i disconnect this connector mashin starts without any errors.
                      • 23010
                      The manual isn't that great for this sort of diagnosis, but I'm making an educated guess that is the Yellow Primary Charge connector. Do you have a yellow IU to try? Or perhaps follow the high voltage cable looking for burn marks from arcing. =^..^=
                      • hooman23
                        • Jul 2014
                        • 57
                        Already tried another yellow imaging unit. The same code. Hv1. Prcb replaced. No luck
                        • Synthohol
                          • 5894
                          so maybe the HVPS backing plate? one of the springs?
                          i mean these doodads, they can short out i guess.
                          see doc.
                          • hooman23
                            • Jul 2014
                            • 57
                            Today im goong to test wiring back of the hvi to charge unite with ohmmeter
                            • hooman23
                              • Jul 2014
                              • 57
                              Replaced charge unite with an old c451 charger. Machin started with no error. Throw c2164 two times. After that table number changed. Problem solved
