Bizhub 326 not funtioning
  • tibbs
    • Aug 2008
    • 225
    Hello everyone here. I am a Canon and Ricoh tech. I have a customer with a Konica Bizhub 326 that has been in storage for 5 years. The machine is new and was still in the box when I followed the installation directions to the tee. Now we have no Konica support out here and no Konica suppliers.
    After I put in the developer and toner I turned on the machine. The machine comes on does not initialize, the LCD screen rolls with no information on it. The fuser is getting hot and that's just about all I can see. Nothing else happens am lost as to what to do next with this machine cause there is nothing on the screen to tell as to what the problem is.
    Any help will be much appreciated.
  • chivozx
    • May 2014
    • 34
    Re: Bizhub 326 not funtioning
    Deja la puerta derecha abierta y enciende.
    Si arranca y te pide que cierres, hazlo y a ver que pasa.
    Leave the door open and turn right.
    If starts and prompts you to close, do it and see what happens
    • tibbs
      • Aug 2008
      • 225
      Tried this and the same thing. Machine aint doing nothing.
      • chivozx
        • May 2014
        • 34
        • tibbs
          • Aug 2008
          • 225
          The problem the screen rolls and there is no image on the screen. So I cannot do a thing. Am not sure why the screen rolls and why there is no information on the screen. The machine does not go through the normal process.
            • 23008
            Are you sure about that model number? I cannot find any reference to a bizhub 326. =^..^=
            • tibbs
              • Aug 2008
              • 225
              Re: Bizhub 362 not funtioning
              Sorry its a Bizhub 362.
              • copier tech
                • 8165
                5 years is a long time for a copier to be sitting unused!
                Have you tried just simply leaving it powered on, see if it eventually starts working, there is a battery on in the machine it's possible that is flat & is causing issues.
                • rrrohan
                  • Sep 2011
                  • 1977
                  What do you mean the screen rolls?
                  • tibbs
                    • Aug 2008
                    • 225
                    The screen like the old televisions horizontally. It lights up but there is no text blank. Plus the machine does not initialize but the fuser is getting hot.
                    • copier tech
                      • 8165
                      Have you tried to make a copy? Put a doc in the DF if the print button is blue push it, could just be the screen has failed?
