Bizhub 600 double imaging and leaving streaks
  • acsolutions
    • Jun 2010
    • 519
    [CQ] Bizhub 600 double imaging and leaving streaks
    Hello, I added a toner recovery roller then a few days later got a call back for jamming in the fuser and streaks! Not sure what I had done to cause this problem! could be drum blade, but see no build up or streaks on drum. I had not checked the discharge lamps yet but wondering if that's a possible problem! No toner dumping and adjusted the used toner auger to drive full time! Any suggestions would be great!
  • Woxner
    • Jul 2011
    • 851
    Re: Bizhub 600 double imaging and leaving streaks
    Could be the drum blade just went bad. Bad ufr will do this too. Have not heard the lamp going bad on these. These blades are replaced at 250k.
